My thoughts are on the next release from AMD being in Q4 of 2013 or even Q1 of 2014 and then not releasing another top card for at least 18 months. I do expect the 8xxx series to nip at Titans heels but not quite make it.
I am purely guessing though and could be miles wrong.
The AMD and nVidia release schedule is tied to the availability of smaller fab processes ultimately.
I don't think availability of high end 20nm GPUs is going to take 18 months, and the drop to 20nm from 28nm is about the same as it was going from 40nm to 28nm.
What's interesting is how much performance AMD managed to get from going to 28nm from 40nm. The 7970GE is about 2x the performance of the 6970, using 33% more stream shaders, on a GPU that's about 12% smaller. Going from 40nm to 28nm means about 30% more space.
The reason I mention that is because if AMD were to straight move a Tahiti GPU to 20nm, you'd get a 7970 performance GPU that's only slightly bigger than a 7870 GPU, with a bit more power consumption.
Basically, the move from 28nm to 20nm means there's going to be a load of room for a load more performance, and whilst it's guess work, there's really no reason to expect it'll take so long for the GTX Titan to be overtaken by a faster single GPU card.
You are entitled to your opinion, the same as I am mine. You are more than welcome to tell me I am wrong if Nvidia or AMD surpass the Titan by March of 2015.
You seem to think that the 8 series will beat the Titan by your way of thinking?
Whilst you are indeed entitled to your opinion, I think it's fair to say that your opinion on it isn't really an informed one.
As looking at the technical aspects of moving from 28nm to 20nm, there's absolutely no reason to think AMD's top 20nm GPU is not going to be faster than the GTX Titan.
If you look over the history of AMD's GPUs, more often than not, they double performance using 30% more GPU space.
3870 > 4870 more than doubled performance on the same process, using 30% more die space.
4870 > 5870, doubled performance using 30% more space on the same process.
6900s don't really count as they are like the GTX5 series, an efficiency refresh on the same process.
5870/6970 > 7970, dropped to 28nm giving roughly 30% more space to play with, doubled performance using about 12% less space than the 6970.
So as above, going from 28nm to 20, they could increase performance quite a lot, and even more if they went for a slightly larger GPU as they did with the 6970s at about 390mm² compared to about 350mm² for the 7970.
