You have nothing to back your claims, the same as I don't. The only rumours floating about ar that the 8 series will still be on 28nm and Volcanic islands will be on 20nm.
Whilst you act out your superiority complex and know it all fashion, you have absolutley no evidence of the claims you have just made. You have not provided any informed evidence of you being remotely correct.
http://www.kitguru.net/components/g...adeon-hd-8970-and-8950-launch-plans-revealed/
Going from that slide, you can see that the 8970 is on 28nm (not sure why you keep on about 20nm?).
Whilst I thankyou for allowing me to have an opinion, bring some evidence next time you wish to call me delusional or uninformed
Edit:
Not sure where you are getting your figures but you are massively wrong stating that the 7970GE is ~ 2X the performance of the 6970
When we look at Anandtech, you can see that your guesstimate of 2X the performance is massively delusional.
http://www.anandtech.com/bench/Product/509?vs=618
Just using the 1920x1200 benchs:
7970GE is faster than the 6970 by 50% in Crysis Warhead
7970GE is faster than the 6970 by 49% in Metro2033
Just 2 examples of how wrong that is and the increases are far less with higher resolutions.
Those benches are very old, using old drivers. I guess you'r not well informed that the newer drivers have seen massive performance gains, which is surprising seeing as you imply you know everything.
