Advice on Z77 mobo and CPU for FSX and video editing
17 Sep 2011
Sheffield
Hi,
I'm looking to build a new PC, and fairly sure I want to use a Z77 motherboard. I'd like advice on which CPU to go for, and which memory and cooler assuming I want to get a reasonable amount of overclocking out of it.
I think FSX (Flight Sim) just needs the fastest possible CPU speed, and gets no benefit at all from hyper-threading. On the other hand, I want a machine that also runs Adobe Premiere Elements quickly (editing and encoding videos), and that probably does benefit from hyper-threading. I thought my choice was between i5-3570k or i7-3770k, but now I'm also wondering about i5-2500k or i7-2700k, which might give me more scope for over-clocking. :confused:
If I'm looking to get 4.6-4.7GHz, do I need to go to water cooling the CPU? I've only used air cooling on previous builds.
And which mobo and memory would you suggest?
Thanks! :)
(haven't fixed a budget yet - just trying to get the basic bits fixed before deciding how much I'll need to spend)
YOUR BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £269.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
2 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £37.99 (£75.98)
1 x Thermalright Macho 120 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
Total : £477.35 (includes shipping : £9.50).
FSX is Nvidia Biased. If you could find a 2nd hand 1GB 460 (~£50 lets say) you would be laughing as you would also cop CUDA support and the GPUs OC well too :)
