when a pc used to hold its overclock......
29 Jun 2004
and doesnt anymore, or sometimes fails to do so, would this suggest component/s are on the way out?
reason is i have one of the i7 920's at 4.00GHz.
how old is it?
what voltage are you on?
as Suarez says, CPU's can gradually degrade and need a small voltage bump to maintain the same overclock... it doesn't mean the chip is on it's way out neccesarily
Are the temps Ok ? Could just need a damn good clean out & some new TIM.
temps do seem fine although it could do with a good dust out to be fair.temps are at low 40s idle.have tried upping vcore but usually it just resorts to the same thing after a few days ie not posting first time .
corsair psu.
just got another bsod. attempt_non _execute memory or seomthing like that.
really tempted just to get a new cpu,mem and mobo.
have you updated the bios recently? each bios will be slightly different regarding voltages needed to remain stable,so you need to re do your oc with each bios version
its either cpu v or not enough qpi/vtt (cpu memory controller)voltage
what board is it? it shouldn't degrade,i ran 4.2ghz on a 920 do and gigabyte ud5 for 3years+ and it still performed like new
if I were you id flash to f12 bios,f13 isn't as good
and set qpi/vtt to 1.315v idk what amount you were using? and dram voltage can be 1.5v or 1.66v depending on your ram
corsair psu.
There's your error bro. Thats the exact same BSOD I used to get when my RAM was going faulty. My browsers and games crashed often, then it would just BSOD out the blue.
Download memtest86 and check your sticks.
MY 920 X58 UD5A OC settings latest Bios, have used these settings from day one
BIOS SETTINGS 4.0GHz -
Adavanced CPU Features - [A = AUTO][E = ENABLED] [D = DISABLED]
CPU CLOCK RATIO----------[a] - 4.0GHz - [21]x191 / 4.2GHz - [21]x201
INTEL(R)TURBO BOOST------[A] - E
CPU CORES E------------[ALL] - ALL
CPU MULTI THREADING------[A] - E
CPU ENHANCED HALT (C1E)--[A] - E
C3/C6/C7 STATE SUPPORT---[A] - D
CPU THERMAL MONTIOR------[A] - E
CPU EIST FUNCTION--------[A] - E
VIRTUALIZATION TECH------[A] - E
BI-DIRECTIONAL PROCHOT---[A] - E
UNCORE & QPI FEATURES -
QPI LINK SPEED-----------[A] - 36
UNCORE FREQUENCY---------[A] - 17
ISONCHORNOUS FREQUENCY---[A] - E
INTERGRATED PERIPHERALS -
ICH SATA CONTROL MODE----[IDE:ACHI] - ACHI
STANDARD CLOCK CONTROL -
BASE CLOCK[BLCK]CONTROL--[A] - E
BCLK FREQUENCY [MHz]-----[A] - 201x20=4.2GHz / 191x21=4.0GHz
PCI EXPRESS FREQ[MHz]----[A] - 101]
C.I.A.2------------------[A] - D
ADVANCED CLOCK CONTROL -
CPU CLOCK DRIVE----------[a-OPS] - 800mv
PCI EXPRESS CLOCK DR-----[a-OPS] - 900mv
CPU CLOCK SKEW-----------[A-Ops] - OOOMV
IOH CLOCK SKEW-----------[A-Ops] - 000MV
ADVANCED DRAM fEATURES -
PERFORMCE ENHANCE--------[A] - TURBO
EXTREME MEMORY PRO[XMP]--[A] - D
SYSTEM MEMORY MULTI[SPD]-[A] - 8x=1608mhZ
DRAM TIMING SELECT[SPD]--[A] - EXPERT
CHANNEL A+B+C TIMINGS SETTINGS[ALL THE SAME] -
##CHANNEL STANDARD TIMING CONTROL##
CAS LATENCY TIME---------8 [A] - 9
TRCD---------------------8 [A] - 9
TRP----------------------8 [A] - 9
TRAS--------------------24 [A] - 24
CR-----------------------2 [A] - 2
##CHANNEL ADVANCED TIMING CONTROL##
TRC----------------------[A]
TRRD---------------------[A]
TWTR---------------------[A]
TWR----------------------[A]
TWTP---------------------[A]
TWL----------------------[A]
TRFC---------------------[A]
TRTP---------------------[A]
TFAW---------------------[A]
COMMAND RATE[CMD]--------[1]
##CHANNEL MISC TIMMINGS##
ROUND TRIP LATENCY-------[A]
ADVANCED VOLTAGE CONTROL -
CPU VOLCORE - 4.0ghz - LLC=L1 - Vc-1.32v / 4.2ghz - LLC=L1 - Vc-1.33v / DYMANIC VCORE[DVID]------[0+00000v auto]
CPU-
LOADLINE CALIBRATION-----[a] STANDARD - LEVEL 1 - LEVEL 2 - ENABLED TO Level 1 = 4.2GHz / 4.0GHz
CPU VOLCORE--------------[0.00000v]
DYMANIC VCORE[DVID]------[0+00000v auto] to set DVID = NORMAl/[1.3250- 1.25625 = +0.06875v DVID] 4.0GHz
QPI/VTT VOLTAGE1.150v----[A] - 1.315v
CPU PLL 1.800v-----------[A] - 1.800v
MCH/ICH -
PCIE 1.500v--------------[A] - 1.500v
QPI PLL 1.100v-----------[A] - 1.140v
IOH CORE 1.1v------------[A] - 1.120v OR 1.100V
ICH I/O 1.50v------------[A] - 1.500v
ICH CORE 1.1v------------[A] - 1.140V OR 1.00V
DRAM -
DRAM VOLTAGE 1.500v------[A] - 1.540v
DRAM TERMINATION 0.750v--[A] - 0.750v
CH-A DATA VREF---0.750v--[A] - 0.750v
CH-B DATA VREF-----"-----[A] - --"--
CH-C DATA VREF-----"-----[A] - --"--
CH-A ADDRESS VREF-0.750v-[A] - 0.750v
CH-B ADDRESS VREF---"----[A] - --"--
CH-C ADDRESS VREF---"----[A] - --"--
Hope these help.:)
thanks will give these a try, had a play around last night, booted ok this morning, if not will use your guide, thanks for that.
