**MEMORY PRICES ARE CRAZY HIGH: KINGSTON JUST DONE A REVERSAL - PRICE DROP ONLY AT OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Kingston like OcUK have old stocks of memory, allowing us to do this on some very high performance kits with aggressive CAS latency timings:-
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £39.95 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
- Model Name: KHX1600C9D3X2K2/8GX
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- M/B Chipset: INTEL P67
- CAS Latency: 9-9-9-27 2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.50-1.65V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM
- Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
- Master Pack Weight: 0.26 lbs
- Black PCB
- Warranty: Lifetime
Was [£59.99] Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-15000C11 1866MHz Dual Channel Kit (KHX1866C11D3P1K2/8G) @ £49.99 inc VAT
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. HyperX memory modules are designed for the high-performance and PC enthusiasts markets and offer high speeds and low latencies. Only the best components are used to assemble HyperX memory modules in order to guarantee the highest performance. All Kingston HyperX memory modules come with a lifetime warranty.
- Model Name: KHX1866C11D3P1K2/8G
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- CAS Latency: 11-11-11-27 2N
- Speed: DDR3-1866 (PC3-15000)
- Test Voltage: 1.50-1.60V
Was [£64.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Memory prices are holding stable, albeit at much higher prices than these Kingston offers and predictions in the market are it shall start increasing again after the Easter break, so whilst were running such deals, now is a good buying opportunity as no one really now knows if the pricing shall come back down again, it certainly won't hit the record lows it dead again. Plus it is rumoured DDR4 might make a showing at end of the year which would mean DDR3 production would be cut, potentially pushing pricing higher, just like how DDR2 prices have rocketed. :(
Cool.
Only bought 8Gb of these a few months back for a new build, might add another 8GB.
Doubt I will actually need it though.
Cool.
8GB is plenty typically, so unless your doing some serious graphics or photography work its probably not necessary. :)
Have 4GB atm,
Worth me picking up just another 4gb or get a 8gb set?
I'm maxing out with 20 tabs of chrome and dota 2 open.
Have 4GB atm,
I'd definately pick up one of the Kingston HyperX 8GB 1600mhz kits.
The cheapest 4GB 1600mhz kit from OcUK is £30, which is £7.50/GB. The 8GB 1600mhz kit is only £5/GB and is generally speaking, awesome. I have a set and have had no problems what so ever. The heatsinks are awesome too :D.
What happens to ram price?
Manufacturer went bust, due to selling to cheap, making no profits. This scared other manufacturers and at the same time supply dropped and demand increased. Forcing pricing skywards, exchange rates have not helped but have little to do with it, just pricing going skywards since Christmas. At Christmas it was nearly like half the price it is now!! :eek:
Have RAM prices gone up a bit? I remember you could get a 1600Mhz 8GB kit for 29.99 at one point with 9-9-9-24 timings.
Was a little later than expected but prices have slowly started jumping up.
Luckilg I bought 3 sets when they were cheap 16Gb in main PC, 8GB for HP server. At the low prices was silly not to :)
iirc Gibbo bought a load of memory and we were being offerred them at the low prices before price increases started affecting OcUK too. *claps* (wheres the emote for that)
