- 28 Oct 2011
Here's the issue, I have ASUS mobo with the suite, the reading for COU is 102- degrees off, ie useless, core temp reports 75 deg under prime, my dumbass suite tells me it's 55 degrees (I have of course used mutiple of these progs at once to make sure)
The useless thing and bios is not allowing me to go back to stock either, only a mild OC of 3.6ghz tho.
Therefore the cpu fan does not speed up and my cpu hits 83 degrees (shutoff point i set with coretemp)
This means any activity (even the map on MTW 2 causes a shut down) - I can play SKYRIM for about 2 mins, causes shutdown.
I really need something that accurately records CPU temp and and controls the CPU fan and ideally the case fans.
Please no lecture on only having a stock cooler right now, I am without a TV and need to save for one.
PS - I did take off cooler clean off and re-apply paste (pea size grain spread thinly, the cooler is set solid too).
Thanks.
Thanks.
Thanks.
Thanks.
