Was aiming for £500 (oops)
25 Mar 2013
Hello
Ive not bought a computer in a while
i currently have an old sony viao pcv-rs running XP a pentium 4ht and 1 gb ram from about 2004 ?
it works fine but its really begining to show its age browsing the internet etc
so anything i buy/build now is going to be miles ahead
I saw the titan prodigy system liked it and thought i could get it to £500:rolleyes:
my basket
MSI GeForce GTX 650Ti OC Power Edition 1024MB GDDR5 PCI-Express Graphics Card £119.99
Intel Core i3-3240 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £115.99
Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
Samsung 120GB SSD 840 SATA 6Gb/s Desktop and Notebook Kit - (MZ-7TD120KW) £92.99
BitFenix Prodigy Mini-ITX Cube Case - Midnight Black £69.98
Corsair 2013 Edition Gamer Series GS 600W '80 Plus Bronze' Power Supply (CP-9020063-UK) £66.95
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £37.99
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
total 621.86
Its not for gaming is it overkill ? just thinking along the lines off the best i can get for my money rather than opting for a off the high street shelf job
love the forum by the way some of the builds are amazing
thanks
Mick
If not for gaming, why do you want (or why did you pick) the SSD, 650Ti, 600W PSU?
If it is literally just for internet browsing then could get a decent system for around £350-£400.
Could go for a CPU/Mobo with integrated graphics, and drop the 650Ti. Lower the PSU to 500w (probably even 400w!). RAM is decent price, no harm in having extra GB. I wouldn't recommend an SSD for an internet browsing build, as the only performance you'd really notice is turning the PC on/off.
Off to bed now otherwise I'd do a quick build spec, sorry! I'm sure someone will come along and help you out though :)
So, is this just for general computing use like browsing the internet and using word processing etc? If so, then yes - that is overkill for such requirements, you don't need a dedicated graphics card really nor 8GB of RAM.
If it is literally just for internet browsing then could get a system for around £300-350.
An SSD is justifiable even if it isn't for gaming. An SSD just improves general computer use by a long way that I can't stand to use a computer system that doesn't have an SSD installed because of how slow/unresponsive they feel in comparison.
However I completely agree that the GTX 650Ti is totally unneccesary for general use. If you are looking for a computer for general use consider getting a different system such as the Primo 6100i:
YOUR BASKET
1 x "Primo 6100i" Intel Core i3 2120 3.30GHz DDR3 Dual Core System £229.99
1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
1 x No Hard Drive Upgrade £0
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £65.99
1 x Standard Build Systems - Approximately 5-7 working days £0
1 x No Graphics Card Upgrade £0
1 x TeamGroup Elite 4GB (1x4GB) DDR3 PC3-12800C11 1600MHz Single Channel Module (TED34GM1600C1101) £25.99
1 x No Operating System £20
Total : £341.99 (includes shipping : FREE).
You could probably pick up an SSD cheap second hard that you can use for OS and regularly used programs (browser, word processing etc).
EDIT: I just noticed for some reason that in the basket, "no operating system" is showing as +£20 whereas on the product page it shows £0. Strange.
mostly internet downloading/listening to music youtube etc
as im limited at the moment with comp i have a new comp might spur me on to other things
not really a pc gamer ps will do for me
I wouldn't buy the 650Ti, if you are not gaming just use the IGP.
YOUR BASKET
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £92.99
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £82.99
1 x BitFenix Prodigy 'Yin' Mini-ITX Cube Case - White/Black £69.98
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £54.98
1 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £37.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £468.91 (includes shipping : £10.00).
The i3 3225 has a better IGP but is a little more cash. If you came across a 2nd hand 1GB 460 that would give you CUDA support and gaming that easily surpasses current consoles and might give next gen a run for its money too. That's what I would do and having the cheaper i3 wouldn't hurt you, the i5 2500K would make it £550ish
P.S
In regard to the OS. There is a windows 8 enterprise (evaluation) edition you can download and use for free on a 3 month trial. If you can reuse the XP licence and you are happy with windows 8 there is a windows 8 Pro upgrade pack
thanks for the quick replies and the different option
think i went a bit ott on a few things :)
so i can downgrade a few things and still have a great computer
the system will be hooking upto my surround sound via toslink
and my lcd tv as it is at the mo
so the graphics are not great and doesnt do hd video on websites
or is slow
memory i just clicked a resonable price ram ill change that to 4gb
the case purely because i liked it dont want anything to big was after something the same size as my sub box
but they seem to be a bit pricey
psu was not sure about at all really
Going mini-itx isn't cheap but they do look amazing. If you are going through the TV might as well consider it a home theatre PC (HTPC)
YOUR BASKET
1 x BitFenix Prodigy Mini-ITX Cube Case - Midnight Black £69.98
1 x Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD £55.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
Total : £511.97 (includes shipping : £11.75).
430/450W is enough, even if you add a midrange GPU. 500W is just a nice round number when you want to add highend cards and overclocking into the mix.
I wouldn't use WinXP but doing the windows 8 trial before you buy the OS makes sense. The metro UI would be easy to navigate from the sofa if that's what you are thinking of doing. You can get free apps for smartphones to act as a mouse and basic keyboard.
Have a look atTHIS video. A forum member built a HTPC/Console killer in the Prodigy chassis and demos his HTPC setup. Granted he does have a dedicated GPU for gaming. You could consider AMDs Trinity APUs as they have a much better IGP than their Intel rivals......ie yes it can play games without needing a dedicated GPU. I realise gaming isn't a priority but I'll discuss the options anyway to help you decide what platform to be on
I don't game but still have a 3570k and 2 gpus :D , folding@home is my form of entertainmt
Look in the b grade section. There's an intel i3 for £50 :cool:
before i was even bothered to upgrade my pc the first thing i got was an SSD , even this alone on an old amd 4400 pc made it feel like a new upto date computer, at the time it was a 64gig crucial ssd , in over 1.5 years now ive not had one single problem with it. according to SSD LIFE, its still showing 100% life aswell :D
YOUR BASKET
Yes mini-itx is nice i quickly looked at other forms but there a bit big for me tbh id love my pc to blend in with the rest of my entertainment ps3/surround sound both are blue ray hence not going for full htpc and 1tb sky box
something like Lian Li PC-C37B Aluminium HTPC Chassis - Black would be nice
the list you put up is good ill have a play around with that
i do have a samsung 250gb hdd sata 3gb/s that with a SSD should be enough
assuming the windows o/s doesnt take up a huge amount
ill have a look at the vid tomorrow cheers for that
never considered AMD lack of knowledge really
I think my pc is passed upgrading tbh
even with a ssd
i added ssd to the list based on youtube vids start up and transfer rates
everything on my computer at the moment takes forever :)
my computer is 2004 i looked into getting a new gpu and they didnt do one that
would run on the psu thats in there 250w i think the only psu for it was 300w
and the type of mother board agp version 3
even with a ssd
i wasnt suggesting add just an ssd lol , i was refering to the above were somebody said why bother with an ssd , i was just stating how good an ssd is.;)
