Man of Honour
- 17 Feb 2003
- Chelmsford
I keep going round in circles here..
Can anyone recommend or suggest 120mm fans that push a decent air flow at very low noise for a triple rad.
Thanks
edit..
Proposed setup
already got:
Swiftech MCR320-QP-K Triple 120mm
EK Supremacy CPU Waterblock
to buy :
XSPC Laing 18W DDC-Pump 12V DDC 3.25 - ULTRA PERFROMANCE - 900lphXSPC Acrylic Top for Laing DDC - out of stock
XSPC Dual 5.25” Bay Reservoir (Alu Front)
XSPC RS120 120mm Radiator - Black
8 x Bitspower Premium G1/4" Black Matte High Flow 7/16" ID (5/8" OD) Compression Fitting
EK-EKoolants UV Blue
XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Blue/UV Blue
res >>> pump >> triple rad >> cpu block >> single rad >>> res
Is the single rad an over kill? I thought it would reduce the ambient temperature in the res before going to the triple.
Also, any got any experience of the Laing 18w? 3.25. Noisy?
Thanks
edit..
Proposed setup
already got:
to buy :
