Advice..what would you guys think of this PC?
26 Mar 2013
Hey, just wondering what people would think of this as a gaming pc...wanting to play games such as Skyrim and Total War on top spec, thanks :)
Case COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
Motherboard ASUS® P8Z77-V LK: PCI-E 3.0 READY, SLI, CROSSFIREX
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Graphics Card 2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 90GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
RAID NONE
SSD CACHE DRIVE NONE
1st DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling Corsair H40 Hydro Series High Performance CPU Cooler (£39)
Extra Case Fans 2 x 12CM Black Case Fan (configured to extract from rear/roof) (£9)
Fan Controller NONE
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities WIRELESS 802.11N 300Mbps PCI CARD (£16)
USB Options 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire NONE
TV Card NONE
Operating System Genuine Windows 7 Ultimate 64 Bit w/SP1 - inc DVD & Licence (£139)
pre built,
1 x "Titan 350i Gelata" Intel Core i7 3770K @ 4.40GHz Overclocked Ivybridge Quad Core Gaming PC £468.00
- 1 x Standard Build Systems - Approximately 5-7 working days £0.00
- 1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
- 1 x Cooler Master HAF 912 Advanced Midi Tower Case - Black £69.98
- 1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £71.99
- 1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £89.99
- 1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.99
- 1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
- 1 x Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £349.99
Total : £1,178.34 (includes shipping : £24.50).
Why You Should Buy This System
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- Cinematic DX11 graphics
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Gigabit Ethernet and WIFI for next gen computing
System Specification
- Case: Cooler Master HAF 912 Advanced Midi Tower Case - Black
- Power Supply: Corsair GS 600w PSU
- CPU: Intel Core i7 3770K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Corsair H80 High Performance Water Cooler CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Primary Hard Drive: Samsung 120GB SSD 840 SATA 6Gb/s Basic
- Secondary Hard Drive: 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM
- Graphics Card: ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive (default choice, options available)
- Wireless: Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
- Operating Systems: Windows 7 Home Premium (default choice, options available)
I'm going to get a monitor off a friend, so the titan 350i is a good buy then? Would it play stuff like skyrim on full spec?
Yes. Although I would recommend building your own system.
But yeah it is a good build. If you get it, make sure you upgrade the parts to what zakblood has chosen.
Sponge, I will say I do like the look of your parts list. Is that everything you need there to build the computer?
Yeah, apart from keyboard, mouse, headset etc...
Also, would building that be better than the titan one that zakblood recommended?
It's pretty similar, although the pre-built is a slightly better spec. But you get a monitor in with mine, and a better mobo/ram. If you don't need the monitor, you can get rid of that and upgrade the graphics card to a 7970. Depends if you are comfortable in building your own or not. I'll re-spec you.
Do i need sound card, or usb ports and stuff...I have no idea ha!
Completely up to you. The mobo will have on-board sound which is decent enough and plenty of usb ports.
