DVD cover image software
4 Mar 2008
Wandsworth
Hi all,
Just wondering what scraper everyone is using to get their DVD info? (Covers/Actors/Synopsis etc)
I've been using media companion but its started to be getting a bit hit and miss.
So what does everyone use?
Cheers
I use Media Center Master. Downloads all metadata, fan art, dvd covers, trailers etc. Brilliant bit of kit.
ahhh, I think my issue is going to be that I have all my movie files in my root movie folder. i.e. I don't have a separate folder for each movie. So that program doesn't seem to like it. Is there and easy way of creating folders for each movie or do I need to go through and manually create ~500 folders?! :( :mad:
Found a solution to the above if anyone is interested
Code:
@echo off
for %%a in (*.*) do (
md "%%~na" 2>nul
move "%%a" "%%~na"
pause
copy and paste that into a notepad file and save as foldermaker.bat
It makes a folder for all the files in the directory its placed and then moves the files into their respective folders.
Quite a neat tool :)
