I would imagine its the same as these things all come from the same oem with a few adjustments for each unit.
Its 240mm too, so will fit more cases than a 280mm rad.
i think they are the same but it just looks a little thinner from the images
YOUR BASKET
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM3) (CWCH100) £81.98
40 x Corsair SP120 Performance Series High Pressure - Single Pack (CO-9050007-WW) £13.99 (£559.60)
Total : £654.26 (includes shipping : £10.50).
hahahahaha![]()
Plus the 10 fan connector cables you need to power all the fans and the rods to hold them all together.
might aswell have a liquid nitrogen cooler![]()
You could build a very good custom loop for under that and it would be practical. Anyways going a bit off topic. Still gonna make some changes before I buy tomorrow me thinks.
even though the 40 fans is overkill, you shoud try 8 of the fans and see if you have an improvement in cooling
You'd need a pretty big case to do it and it would just increase the cost further. I'm sure the h110 will do a decent job with its stock configuration![]()
What's this motherboard like? http://www.overclockers.co.uk/showproduct.php?prodid=MB-393-GI&groupid=701&catid=5&subcat=2261
I know it's micro atx so may look funny inside a full size tower like the 500r but from the reviews the motherboard seems superb. I just feel like I'm skimping out though buying a cheap motherboard when all the other parts are high end.
i dont know how it is performance wise but it looks awsome, love the colour green. is that the main colour youre going for ?
I don't have a colour preference tbh, might just go with the sabertooth.
It's your choice, but I think green builds look really good in general, what was you're budget ?
I don't really have a budget anymore, it's went way past it already lol.
