[PCWORLD] AMD provides a sneak peek at its Radeon HD 7990
Couple more pictures of the 7990. Bloke not included afaik. :p
*snip*
That's a pity, Matt, would have been a definite buy. /gay :p
I was looking forward to this late last year and was considering buying, but they left it a little late, at least for me. You never know though, depending on the price, I may jump on one at some point simply for benchmarking.
I wouldn't want to go back to multi-GPU gaming any time soon, though.
I won't judge you Proto. :D
We both have golden clockers but if you had a 7970 that wasn't such a good clocker it would be an even more attractive proposition.
Yes, the 7970 is serving me well, currently dominating the UK enthusiast league at HWBot. :D
Have you not considered signing up at HWBot, Matt? I am sure you will be challenging me in no time, as usual. ;)
Why is he suspended?
Good question, though, there have been posts deleted so something might have triggered it during that time.
Will have to wait and see, not sure what was said. :(
Most likely for the aspergers comment he made. Was out of order tbh.
Can't disagree, if true.
Doesn't sound like something Matt would say, though.
There must have been some provocation.
Edit: best to try to keep it on topic guys :)
7990!
Who cares what it looks like? Performance and acoustics are more important to most than a flashy looking cooler.
To me it matters. It just looks like cheap tat. Not to say I wouldn't buy something based on looks alone but it would factor in if everything else is roughly even. (e.g. price and performance)
it pains me to have bought Titan's and had to take the coolers off to put water blocks on... they are works of art in their own right... I would love to be able to work out a way to incorporate the original cooler shrouds back in to the system
I agree. If the cooler does a good job and the performance is there then looks come in last. My machine is there to be used and if i look in the window i can't see the cooler anyway.
few names on there, I never really thought about going on that.
Sorry for OT but we are talking looks of the card now:
That is how to make the card still look good whilst water cooling.
when the software is properly coded to take advantage of the multicore nature of the CPU or for that matter, GPU
which is part of the problem... this is where problems with performance and microstutter come in... it doesn't really matter if the GPU's are stitched together on a single package or not, if there's a problem with a particular game on mulit-core CPU's or GPU's then the offending game runs like it's being run on a much lower grade of chip
things have gotten a lot better in respect of mulit-core CPU's as they've become more widespread, lets hope the same happens with multi-GPU related technologies
One of the key things here will be bringing two dies together on package with low latency and ability to share memory space so the driver/architecture can be focused to work in such a way. SLI/xfire is and always has been a work around, they work as two separate units in a not bad, but not perfect way because they are designed around the limitations of high latency, low bandwidth communication and so load balancing and working on the same frame brings with it so many issues. Multi-cpu's work smoother because the crapload of on die logic and no problem switching data from one core to another seamlessly has basically been there since day one of the second core being added, and has only improved over time.
Ultimately once you move the second die on package and improve communication to almost on die speeds/latency, xfire/sli will pretty much be done from the ground up to work very differently to now.
What is it with AMD people, Fraps shows AMD cards have worse stutter, can't fix it so let's just say Fraps isn't valid anymore. Don't have a Titan-beater so let's start calling a multi-GPU card a single.
So, nonsense from what I can only believe is an Nvidia fanboy? Did I say the 7990 was a "single" gpu, no, I said if/when AMD stick two dies on the same package and can basically do things very differently, they'll be able to completely change the way xfire works and there is no reason to believe it would perform noticeably differently to a single GPU, same will go for Nvidia.
Someone stated as fact it was a dual gpu card, I merely suggested the possibility it will be a new breed of multi gpu card.
The fact is on multiple dies on the same package using new tech is coming THIS year, and AMD has worked on this for console chips which ARE in production and have been for some time. Its a possibility and I like the idea they MIGHT have gone this way for the 7990... considering its about eleventy billion seconds too late to be remotely interesting as a card without it, nothing more or less than that.
As for AMD latency, no clue about fraps, I haven't used it in ages, it actually got really dodgy around win 7 release, I forget what the issue was but it was mis reading frames, I'm sure its fixed but ultimately I like smooth, not a number, I can feel smooth without a number so why do I need something else installed. But, AMD is working on latency and has fixed the latency issue in some games, and are working on it for further games.
So basically nothing you said was accurate, well done.
It's the only recognised overclocking league, so I would say all the 'names' are on there. I would join, if serious about overclocking. I have been top since borandi went pro, less some hours, It would be nice to have some decent overclockers challenging. :p
Well I was top for a few days and then played games instead :(
