Well I was top for a few days and then played games instead
don't those images of hwbot league list competitors names?
It lists whatever name you choose to go by, there's no need to use real names unless competing in an event that requires it. Even then, they would probably prefer the name your are generally known by, would not be much advertising for the organiser's products, otherwise.
No I was meaning that it lists competitor websites, for example A*** PC is a definite OCUK competitor.
?? i though the 7990 was released ages ago http://www.overclockers.co.uk/showproduct.php?prodid=GX-007-OE
isnt this just another custom overclocked version like the ares 2?
if they've improved it in someway they should call it something else like the 7995 or something!
Sorry for OT but we are talking looks of the card now:
That is how to make the card still look good whilst water cooling.
Show me where 4 other cards can compete? Until AMD release a card that competes, Titan stands on top of the tree gloating
Haha Fair play Dave and he is using that comp for number crunching![]()
I bet it would still get fps drops in Crysis 3![]()
looks really cheap tbh. the 690 and Titan looks way nicer.
I hope thats just a press version and they come out with a less plastic looking cooler
What is it with AMD people, Fraps shows AMD cards have worse stutter, can't fix it so let's just say Fraps isn't valid anymore. Don't have a Titan-beater so let's start calling a multi-GPU card a single.
Next we see the exact same run through only now we have loaded RadeonPro with a custom profile to set an FPS cap of 50. Vsync is off and no briple buffering. Much better experience, I have done nothing other than add an FPS cap and the experience is far, far better.
Pretty much everything you said is wrong apart from FRAPS showing worse stutter.
Here are some FRAPS frame-time graphs from Tomb Raider level Summit Forest.
Crossfire is a stuttery mess out of the box and AMD need to get their act together.
Crossfire deserves a lot of the negative press it has received
But it need not be a pointless waste of money
Crossfire stutter can be fixed/improved as long as you know what settings to play with in RadeonPro to get the best out of it.
SLI also causes microstutter and in many cases does require tweaking to fix excessive stutter, but it is still working far better out of the box.
