Maybe
The T&S stuff that has impressed me the most from other photographers is where the focal plane stretches from within reach to infinity.
Andrew
Challenge accepted !
It has only been 2 days though so I am still getting the hang of this lens.
Manual focus aside, the thinking behind taking a photograph when using a TS lens is on a different level or to be more accurate, a different dimension compare to a normal lens.
With a normal lens you just pick the subject, and compose.  It is in a way a 2D exercise.  The AF does the focus for you and you only worry about X & Y mostly.
With a TS, soon as you tilt, you can "visually" see the DoF pane (as long as the focal pane lands on something then you can see how thin or thick it is).  Focusing is no longer trying to focus, it is more like moving that focal pane from left to right or top to bottom until it lands on what you want to focus on.  Depends which way you tilt, the focal pane (along with distance to the side of that) is either near or further away from you.  So if you tilt right and there is a person on the left side of the frame you may not be able to land the focal pane on it, it just doesn't go that far, depending on how far that person is away from the camera.
Now in a real world situation it means you might have to tilt the lens to the other side instead.
Then comes to exposure, because you are bending the light.  Tilting the lens to the side can either cause more or less light in to the value of 2 to 2 and a half stop.  So it can be a total of 5 stop from tilting from top to bottom.  This is in Av mode even.  The metering just goes out of wack totally.  So that is something to think about.  I am slowly learning which way to nudge that exposure compensation dial on the fly by the direction of tilt I am using.  I still get it wrong more times than i'd like.
The miniature effect isn't really what i bought the lens for, it is however a side effect that i am playing with and when you are high up, that is the obvious thing to do I guess.  The thing I am learning to do is get that focal pane to land on the subject i want when i want it at F/2.8.  I am not sure who has or hasn't use a TS lens and imagine using just the viewfinder to see if something is in focus, it is not easy so that's what i've been trying to do mostly.   Using the focal pane to show you what i want you to see, the miniature effect is a side effect of it really, albeit a fun one.  Like I said from the start, this is a learning exercise to see what works and what doesn't.  Shooting the entire trip this way will give me more idea than doing it now and again.
Now to your challenge of using the focal pane and infinity, if I get what you mean, that is like shooting in not 3D but almost 4D.  Not only you have to compose (2D), then focus (3D), and do it in a way that the focal pane goes in a direction so in the infinity of it, it also has something in the distance as that is also a point of focus.  So you need to line up the focal pane, something that you can't see, unless an object cuts it.  The hardest part come with knowing the angle of direction it goes and actually seeing both in focus, not easy doing it in a viewfinder, much easier with the LCD (don't get a chance to do that on the street, been told off twice in 2 days for taking photos in shopping malls!
			I don't like them. I can see the use of a TS lens for fixing verticals etc., but I'm not a fan of the 'toy town' look.
I really do think you missed some good shots here Raymond if you had taken them with a normal lens. As someone has already said, the colours are great and quite clearly some of the subjects are out of the ordinary, but the TS effect just doesn't look good in most of them.
I have 4 years' worth of photos with other lenses so I am not missing out, at least I don't think so.  I will try something different again next time so this is an experiment that i want to do for a while.
