YOUR BASKET
2 x Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £323.99 (£647.98)
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £279.95
1 x Asus P8Z77-V DELUXE Intel Z77 (Socket 1155) DDR3 Motherboard £209.99
2 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black £167.99 (£335.98)
1 x Corsair Obsidian 550D Quiet Midi Tower Case - Black £119.99
1 x Corsair Professional Series HX+ 750W '80+ Gold' Modular Power Supply (CP-9020031-UK) £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (Socket 1155 / 1156 / 1366 / 2011 / AM2 / AM3 / FM1 / FM2) £99.98
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £89.99
2 x Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) £59.99 (£119.98)
Thanks for that
My main questions about my build are, that i read that if i have two of those graphics cards the heat spreads around the case. Also there might be a better graphics card option for me to go for?
I aren't sure if that is the best ram for my setup. As in speed/amount ect.
Finally i aren't sure if that case is the best either due to me having two cards.
Thanks in advance
Stu
You have a case that specialises in being silent, not one that specialises in cooling performance. I'd get another case if I were you, everything else is fine and GPU's are amazing.
For that price you can get NZXT Phantom 410 which would be perfect, looks wise, space, cable management and airflow, keeping your internals VERY cool as opposed to a case that is noise dampened. Noise dampening = more heat.
it's a very high spec build, just a few question as i'n not too sure i see what your after doing, if you don't mind before you buy,
why 2 X 7970?, the 7950 are a lot cheaper and clock to the same speed?
why not also go to the 2011 socket i7, again same speed for some tests, slightly slower in others and also faster in some so a mixed choice tbh, and again cheaper?
1 x Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - OEM £235.99
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £179.99
1 x Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-14900C9 1866MHz Dual/Quad Channel Kit £99.95
Total : £527.33 (includes shipping : £9.50).
reasons for going this way, later socket so can upgrade chip without changing board at a later date, better use of some features, like ram etc, pcie etc, usb and slight boot speed increase
my choice of board supports crossfire 2 x PCI Express x16 slots, running at x16 with your's 2*PCIe 3.0 x16 slots (1@x16 or dual@x8); 1*PCIe 2.0x16, i'm not knocking asus either as that's a great board and i pick asus over other makes all the time and have them myself many times over in many many builds
why only a smaller sdd?
why 2 X 23.6" screens at £167.99 (£335.98), and not 2 x £179.99 (£359.98) for a few £ more you could have more space, money saved on different choice of cpu and m/b tbh
ram seems to have some issues if i can remember 8packs post on OC them, not knocking your spec either and a good high quality spec and i'm sure build as well if you go ahead with it, just a different opinion that's all
but that's your call, just giving you the options
Yes, you can fit almost any cpu cooler in the phantom 410, its a very popular good quality enthusiast case. Its what I recommend but it May be worth while looking at reviews about it so you get a better idea. You can pretty much fit anything in it.Thanks, does this case support the CPU cooler that i want?
I wanted the case that was recommended above but I wasn't sure if the cpu cooler would fit. I think I'm finally ready to buy it all. Just have to finish work and hope oc is open still.
YOUR BASKET
2 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £239.99 (£479.98)
1 x Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard £232.99
1 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black £167.99
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - Black £109.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £79.99
Total : £1,644.55 (includes shipping : £14.75).
Just posting this so i can load it on my phone and go to the shop.
