Windows 8 Pro
20 Oct 2002
North West
I want to install Windows 8 Pro onto my laptop and my main PC. Can I buy a version that will cater for this or do I need two separate versions? Also which is the best version to go for? Ideally I'd rather perform a fresh install in both instances.
Two separate ones.
Assuming you have licenses already then the upgrade. It gives you an option what you want to do upgrade, keep files, keep nothing.
u must own a previous os license, as thats a upgrade version. if you have then yes it can used like a full version e.g clean install
You can use the upgrade version to do a clean install, but a few things would need to be done before it can be activated.
