I have a Counter Terrorism Check already so hopefully the wait for SC isn't going to be that long.
I don't think it matters, each is treated separately afaik.
They do ask for previous vetting clearances on the form, so I assume they do refer to them. It's under three years old too.
What the average time that the FCO take to complete SC clearance? How long did it take you to be vetted are you a foreign national?
SC is a couple of months max I think, but not really sure.
DV is about 6 months.
What stops you being cleared for SC and DV ?
I have a crim record for assualt, not jailed about 6 years ago, will this stop it ?
Depends which vetting agency you go through, as some seem to be more efficient than others at handling the paperwork.
I'm specifically after the form that goes to the FCO.
