So can we expect ea's new favourite microtransactions in this?
Im excited to see mp either way
It will indeed.
Ping, hitbox, latency it was a joke with Bf3.
same as with Bc2.
the trailer of BF4 looks great and is their best as far.
BFBC2 has far better hitreg than BF3 ever had, Bf3 can be just as bad as BF2. They knew that hitreg was an issue by putting in that useless network slider
Still though Battlefield 3 was perfectly fine before they released that first dlc, then it went down hill.
BC2 was broken as hell for a long, long time after release.
BF3 was also broken from alpha, months into release.
Last I checked they improved BC2 a lot and in BF3 I no longer die seconds into cover or think I should have killed someone. Experiences may vary.
Some nights BF 3 would be spot on, but then half the time it would be dreadful, the network slider does **** all and I cba fiddling with it every damn time I want to play a game.
As someone else said, it isn't a problem with people's connections, it is a problem with the game otherwise it would be the same in every other online game. If there wasn't a problem then DICE wouldn't have put that stupid network slider there in the first place.
One reason I refuse to play Bf3.
netcode, skill level absent etc...
there is some slimmer of hope for Bf4 though,
Bach said " there are things under the hood we're doing that will improve the experience."
they took note BF3 didnt have the battlefield experience....
hopefully it will improve the tech netcode, hitbox and such.
Not holding my breath yet though.
hahaha u belong on the BL forums..
my game how ive got it setup with fxaa injector 1080p with everything on low except Mesh.. still looks better then everything on the standard ultra settings with HBAO 4x MSAA etc
if u had the slightest clue about BF3 u would understand why people play with everything turned off and it has nothing to do with gaining advantage in seeing things first but ill let u figure that one out urself!
Client side is better as it makes it more a level playing field! Server side hit reg u wont find players playing on servers out of there own country because of the delay!
I still prefer server side tho but ill only play on uk server! Maybe french too!
Best ever netcode was quake 3
