Asrock P67 Fata1ity
i7 2600s @4ghz
Inno 3D GTX 680 Herculez
8Gb TEAM @1600
1GB HDD
800w Power Supply
Hi and ty for reading.
I'm considering doubling up on my GPU setup but i'm not entirely sure whether my Power supply will be enough. Also the supply is not even a expensive make or model, is this much of a concern for me?. Could anyone tell me if i should be looking to replace it before buying the 2nd card. And if so with what supply? I have the above setup in a CM HAF-X case and when i put it together i remember there being a long reach for the ATX cable, it only just fit, so if i do need a new supply for my plans then good length on cables must be a factor also.
Many thanks for any responses.
i7 2600s @4ghz
8Gb TEAM @1600
1GB HDD
800w Power Supply
