Anyone have issues with AMD 13.3 drivers or Afterburner beta 7?
16 Mar 2012
Chelmsford,Essex,UK
The reason i ask is that i have had 3-4 pc lock ups in the last 2 days, and they were the most recent drivers/programs i upgraded.
Also Afterburner i notice it says my mv is 1175 instead of 1174 like it used to:confused:
And i have noticed say i reboot with my GPU over clocked when i open Afterburner my clocks are the same but my voltage has reset to 1175, not a major thing but i thought thats why i was getting freezes at 1st.
But i just got a freze on stock settings.
Thanks
Thanks
Afterburner seems to have less vdrop now and slightly higher voltage. I've noticed the same as well. Its good though as i got a little bit more from my core clock speeds. Not noticed any problems here. Sounds like you have some instability somewhere that you need to troubleshoot.
If you're convinced its afterburner might be wise to ask Unwinder about it on the guru3d forums.
Afterburner causes my pc to redscreen on 13.3
So I removed it and use ccc ocing and gputweak to raise volts.
Perfect
Are you using windows 8 by any chance? I used to get the exact same problem sometimes. Turned out my cpu needed an extra bump of voltage and the red screen never came back.
