2 x 1GB cards or 1 x 2GB card?
17 Mar 2013
Hi all,
I'm speccing out my new build and I'm unsure what would be better; a single 2GB graphics card, or dual 1GB cards. Can someone give me a hand?
My budget for the card(s) is £170~; I am planning on an AMD based system.
Thanks in advance guys!
dual 1gb cards only have 1gb still.
a single 2gb card would be the better option.
7850/7870 is your area i think.
First off the mobo would need to do SLi/Xfire properly and running two GPUs means you will need more than a 500W PSU. 500W is ample for a single GPU setup. When you have two GPUs the VRAM isn't combined so if you go for a 1GB GPU even with two GPUs that is all you get.
In short a single 2GB GPU is most likely your best option and overclock it......
YOUR BASKET
1 x Sapphire HD 7870 XT rev2.0 2048MB GDDR5 PCI-Express Graphics Card with Tomb Raider & Bioshock PC Games £203.99
1 x Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card with Tomb Raider & Bioshock PC Games £161.99
Total : £365.98 (includes shipping : FREE).
Thanks for the advice!
The Gigabyte card is more my price range
You can't link to competitors fella, I'd remove that link. You can link to the manufacturers webpage though.
The 7870XT is closely related to the 7950 (£240ish GPU), so isn't really a 7870 at all. The fact you cop some free games too makes it even more of a bargain, it's worth the extra cash for sure ;)
