- 23 Mar 2010
well, basically i plan on getting a new monitor, but im not sure which,
so problem is:
24" 1920x1080
or
27" 1920x1080
27" 2560x1440 seems too expensive, and i may not have the budget for it.
any ideas on which i should go for?
so problem is:
24" 1920x1080
or
27" 1920x1080
. I would say base your choice on the size you feel is most suitable for you and don't worry about the resolution.
