Caporegime
- 9 Nov 2009
- Planet Earth
I might look at selling up my AMD parts like suggested and moving over to intel. but does intel preform better in other games as well? such as crysis and CoD for example.
also if i do go about selling it any suggestions where to sell it in the UK?
Why don't you just make sure your rig works first??
On tech forums,there is a tendency to solve problems by throwing hardware at them first.
I know people with slower CPUs and GPUs than you,not having problems in WoW on the settings you have described.
There are a lot of WoW players out there who don't have expensive hardware. Even that chap I know with the overclocked FX6300,is using an HD5850 1GB at 1920X1080.
Edit!!
What case are you using?
What previous graphics card were you using?
1.)Run both of your 4GB RAM sticks in dual channel.
2.)Update your BIOS to the latest one,on the Gigabyte website.
3.)Make sure you have some good airflow in your case.
4.)Your CPU is running too hot. If improving the airflow does not help,re-attach the cooler with some better thermal compound.
5.)Monitor the clockspeed of your CPU when running a game. If it goes under 4.2GHZ,you have an issue.
6.)If there is an issue,see if blowing some air on the VRM,changes anything.
