Caporegime
- 13 May 2003
- Warwickshire
Hello
We specced the standard RCD 310 when we ordered our Golf back in 2009, so now it's out of original manufacturer's warranty, I'm slightly less paranoid about fiddling with things and am thinking of upgrading the radio. This will probably mean the latest RNS 510 touchscreen Satnav jobbie that I can get my hands on.
I've looked around and there's a wealth of information on the web about the actual process. It sounds like a straight swap, plug and play apart from some VAG com re-coding to get the turn by turn instructions on the highline display.
However I have some other questions that I haven't covered off, so if anyone here can help that'd be great:
- Which model Rns should I be looking at? There seem to be so many versions I have no idea which I need.
- Any recommendations as to places to source the unit?
- Highly subjective question, but is it actually worth it? I don't use nav that much, but fancy the extra media functionality for music and videos etc. I think it'll improve the look of the car and make it more saleable.
- What are my best options for adding dab radio and blue tooth once the unit is installed?
- Where's the best place to buy the vag com bits and bobs? Do I just need the cable and a cd?
Not sure how much non-Audi vag knowledge there is on here, but I might be lucky!
