What the average House prices where you live ??
I just done a little searching and I can't believe how cheap houses prices are in England...
Says average House prices are only around £238,293 :eek: that crazy low
No idea on average but round here you are looking at £50-60k for a terraced house, £120-140k will buy a 3 bed detached with garage
Sarcasm? That's not low imo.
I'd say average in Leicester for a 2/3 Bed Terrace is £100k.
Average for a 3 bed semi is around £190k for non-new build.
Average for 3 bed detached varies but on average, £220k seems like a good midpoint.
Though I'm only basing it on the areas I know (which is most of Leicester)
Around £500k as the average across all property types. For a detached property it would be around 700k.
For clarity- I live in berkhamsted, Hertfordshire.
It is still a lot cheaper than central London where we used to live. Our two bed apartment in Maida vale is worth as much as a detached house in berkhamsted.
Claygate, Surrey:
Code:
Mar 2012 	   Mar 2012 	   Mar 2013
Detached           £1,178,281      £1,084,324 	-8%
Semi               £501,380 	   £453,800 	-9%
Terraced           £345,000 	   £631,238 	+83%
Flat 	           £295,965 	   £356,928 	+21%
All 	           £952,710 	   £1,002,740 	+5%
http://www.home.co.uk/guides/asking_prices_report.htm?location=claygate&lastyear=1
EDIT: That seems a bit wrong to me though as it says a terraced is now worth more on average than a semi. I guess it must be down to the actual locations of each I suppose, with the terraced houses being in more desirable parts of Claygate? Shrugs.
that site shows the averages here as
Detached £176,402
Semi £105,221
Terraced £89,538
Flat £64,032
Those prices seem quite a bit on high side to me
Using the above site;
Detached - £759,328
Semi - £385,471
Terraced - £286,643
Flat - £217,293
I'm never gonna be able to afford to buy my own place :p
Code:
  Detached	£314,640	£343,497	+9%
  Semi        £163,620    £164,031    +0%
  Terraced	£130,448	£129,670	-1%
  Flat	        £110,005	£98,832     	-10%
  All	        £177,621	£189,673	+7%
Seems about right
Mind = Blown. You need 180k for a flat round here. I knew there was a bit of a north/south divide but not that much! Do the wages vary that much aswell?
Mar 2012 Mar 2013 Change
Detached £1,023,828 £1,138,891 +11%
Semi £519,316 £488,450 -6%
Terraced £442,015 £514,410 +16%
Flat £295,546 £310,923 +5%
All £751,037 £831,433 +11%
Seems a little high to me.
The 4 bed with garage and three berth drive I'm in atm cost less than £180k.
Wages do vary considerably yes, but not as much as house prices do.
Sep 2006 Mar 2013 Change
Detached £347,797 £425,363 +22%
Semi £247,408 £252,452 +2%
Terraced £203,323 £215,856 +6%
Flat £171,534 £150,840 -12%
All £239,998 £254,684 +6%
I can't see how these prices are sustainable long term.
