You might find 5x5 to be too much volume as a beginner (If you are one like me). When I first started a few moths back, the Starting Strength program seemed better to me. It's basically the same thing, just 3x5 instead of 5x5.
you start with just a bar (no weights) in stronglifts, therefore 5x5 is absolutely fine, by the time you get to the "real" weights you should have been lifting for a couple of months surely at least by then
Would it be worth me paying for a 1 to 1 session for the first couple of times (only £15) and get them to show me the correct form or am I over worrying??
The main problem with this is that you may be getting potentially wrong or even dangerous advice. An instructor at my gym recently told me that I need to keep breathing while squatting, because holding my breath will give me high blood pressure. If you try breathing during a heavy squat, you will almost certainly fall over and hurt yourself. Also exercise causes an inevitable temporary rise in blood pressure anyway.
best programme for noobs who do not know what they are doing or looking for.
Big lifts will cause blood pressure values in the region of 300/200, so whilst the PT was in the right galaxy, he wasn't even close to the ballpark.
And any workout will cause you grief for the first few sessions, particularly if you're not used to strength training!![]()
Exactly. Isometric exercise will cause a greater rise in blood pressure than dynamic exercise, but it's absolutely fine. PT was talking about it as a reason to not hold breath as she 'does not want to be dropping me off to A&E'![]()
.Ofcourse you hold your breath.
Imagine this situation......your car dies on a railroad crossing, a train is in the distance bearing down on you. You go to instinctively push the car off the crossing, how do you do it? Without being careful of your 'breathing pattern' that's for damn sure! You take a big gulp of air and bloody push, maybe grunting a bit but definitely not breathing in and out!
I don't want any sarcy comments about just legging it and leaving the car, I'm trying to prove a point.
