Plumbing help. Plastic pipe and compression fittings
Caporegime
21 Oct 2002
Here
Hi.
I've had a nightmare just now. I have replumbed my bath with 22mm speedfit pipe and compression fittings.
I have turned the water on and most of fittings are leaking where I used plastic. The copper fittings are fine and so are the speedfits in the system.
I did the fittings up pretty tight but was slightly wary of breaking the inserts.
So what have I done wrong ? Even though they were all tight some would spin and some came off with a yank. On inspection the olives have bitten in to the plastic a bit. The olives are brass rather than copper.
PTFE time ? :( or just tighten them up even more ?
You are using pipe inserts in the plastic pipe, & the fittings are normally grip & seal.
Also you should use copper olives NOT brass as it's to hard to compress properly, the connection should not need more than 2 full turns after the olive has gripped the pipe.
Thanks.
Plastic is cut square and using the standard inserts without o ring as recommended. Pipe is 22mm speed fit. I have 2 90 deg elbows for the bath tap manifold and also the manifold 22mm to 1/2 inch fitting all having plastic pipes.
The T pieces off the old bath circuit ( now feeding sink are a mix of copper and plastic).
Looks like brass olives and maybe some JetBlue sealant are my friend ?
Yeh they came with the fittings :( I was careful to avoid over tightening so hopefully I can just swap brass for copper ? Is ptfe worth adding?
No water in my house :( fail
Are you using copper compression fitting to speedfit, I always found it easier to use speedfit straight joiner or reducing straight to join plastic & copper.
Link: http://www.jgspeedfit.com/Home/Tech...al-Downloads/118/DIY-Installation-Manual.aspx
Don't use much plastic myself, I'm old school copper pipe & solder user.:eek:
EDIT: Shouldn't need ptfe.
Yes, you can swap brass olives for copper olives.
Brass olives are for copper pipe, use them in plastic pipe & you will never get a water tight seal.
Seldom use ptfe tape, I tend to use Fernox Water Hawk jointing compound if needed on copper compression fittings.
One benefit it's approved for drinking water pipework as well.
Thanks for the help, I lifted the tank stop cocks and turned on the mains only to at least have some water.
I am using copper compressions to speedfit, mainly for the smaller size and what I thought, more robust fitting as they will be difficult to get to.
Will be off to get some copper olives and jointing compound later.
Before, due to installign marmox boards I would have to tweak the piping and also its only 15mm at moment. 22mm runs to where bath was.
I replumbed with 22mm and chased into wall. I used compression thinking they were more robust - and benefit from being more compact
Wow! what a mess of copper pipework.
Ah,I see what you done now, using copper compression fitting to join two plastic pipes.:(
You install Speedfit correctly you will not have a problem, work I did 10 years ago with HepO2 is still solid, shower I got here was done 3 years ago with Speedfit is still perfect.
Better off buying two speedfit Eblows, two speedfit tap connectors I think, if everything is leaking & you can't salvage it with copper olives.
When I've been faced with similar situation, I always make the chase cutout slightly deeper to accommodate the fitting, easier than mixing & matching.
Yeah the airing cupboard is at top of the pic and boiler is underneath, also the piping to a radiator goes that way too.
How I left it last night:
I can see that now, lets see how copper olives go. I still need to fit into the tap manifold with some sort of fitting as I don't really want the speed fittings in the wall.
I though having plastic pipes does away with the need for earth bonding? The metal taps etc are now isolated from earth.
I guess if it all goes wrong I can go for speed fits and new pipe - the current stuff will be affected by the olive, although i guess it does go deeper into the speed fits than the compressions.
I honestly thought compressions would be better, easier to fit and more durable :(
Looking at your pic, you have used a plastic tee from copper to plastic, back to copper, you should install a bonding conductor across the fitting to maintain the conductivity.
Ah the straight under the floor? That's connected to plastic again (after a 90deg bend just out of shot.
