- 25 Jun 2012
Hi all,
I'm new here so please don't go mental if there's already been a post with with a topic along these lines about the same card - I really want to know about your opinion on my specific settup and card!
I have a Saphire 6950 2GB Dual Fan "OC Edition" which I bought here months ago, which has served me well as a GPU, but I want to actually overclock it now that I'm happy with it running stable at stock clocks.
At stock (currently) -
I think one of the problems may be that there's no extraction fan on my case near the GPU. There is a 200mm intake (bottom front of case), and a 200mm & a 120mm outtake (both at top back of case).
If it would help allot, I could mod my case to put a fan on the side window of the case next to the GPU to extract hot air? My case is a CoolerMaster Storm Enforcer if it helps. I'd put the fan on the transparent bit on the side (see picture)
http://images.tweaktown.com/content...rm_enforcer_mid_tower_chassis_review_full.jpg
Any advice on whether or not my GPU temps are good, whether I should overclock/how/by how much, whether I should add a side fan (thus voiding case warranty), and how to improve cooling performance would be greatly appreciated!
Thanks,
Luke
- The card idles at 39-41C (Is this bad? It's WAY higher than my CPU idles but people say that GPUs are hotter by nature... I have no idea, please elaborate?)
- Under load with furmark I can get it to a max temp of 69C (Innuendo unintended) but it averages at about 67C throughout half an hour or so of 100% load very stable with no fluctuations.
- The fans run at about 27% at idle, and under 100% load they were running at 40-48%. Is this good/normal?
Thanks,
Luke
