Spec me one, must be BPL for the links with Clichy, Kompany & Toure, and, oh, Argentinian to 9 up Lavezzi
Might try Pique again today, make a 4321 random hybrid with IF Villa and see what happens!
Not using Casillas again though and Diego Lopez was sadly underwhelming, I may bite the suicide GK bullet and try Diego AlvesHe has amazing times and terrible times, reminds me of IF Cesar last year!
The easy thing would be to remove Lavezzi. Replace him with Robben or similar - which then allows you to use RVP as a CM or IF De Guzman.
Or if you swap Ribery and Lavezzi, then get ridof Ribery for Robben or another. You can swap Tevez. Or use someone like Pastore. Silva will have many links to those in front allowing you to swap out Maicon for someone who doesn't play in the BPL. For example, Van De Wiel, who would link to RVP or Guzman in front.
Lots of options!
