Heh, just about to ask this.Is the 90 degree bend a folded edge or welded?
Also, tolerances, what are they?
Folded would be fine
The big square holes are more than big enough to fit over some other stuff so the tolerances on those are much wider, say +/- 2mm or so.
I imagine you may have some accuracy issues with folding a 2mm piece in that exact location, due to the location of the hole. However the rest of it looks fairly simple - +/-2mm is a fairly wide tolerance, I'd be asking for less than 1mm.
The hole wouldn't have to be flush to the bend, it could be up to 3mm away
Needs a more accurate drawing then![]()
How do I do a more accurate drawing of something that doesn't need to be as accurate as the one I have done?
You may be right, but most normal people would get the gistIt's not something that would be CNCd.
It looks to me as though the hole on the upright section is flush with the fold; if you send that to a company to be manufactured they'd assume that's what you meant. Given that pretty much every other feature on the drawing has dimensions, why wouldn't you add a dimension to that part, if it could be up to 3mm away?
