Mine has 350 HP. I guess the RS3 suffers at higher speeds due to the drivetrain. Where do you get they have low weight from? The Audi figure seems to be 1575 Kg, presumably their usual excluding driver figure, so 1650 Kg including. The E60 535d is only 1735 Kg!
EDIT: Confirmed, 1650 Kg including driver (206 HP/ton): http://www.schwab-kolb.com/audi/en/etd_rs_3_sportback.pdf, so a whole 85 Kg lighter than a 6 cylinder diesel 5 Series. I'd call that pretty overweight for a little hatchback
The M135i has 213 HP/ton.
Shhh you. It's still a rapid hatch
Single turbo and peak torque starts at 1300 revs.
I can honestly say I've never been in a car, except a 997.1 911 Turbo, that pushes you into your seat so aggressively at minimal revs.
