i7 on the cards at last [£800 max]
6 Apr 2013
I have finally decided it's time to scrape together and get an i7 together and since Overclockers has always been coming up over the years when looking thru things I thought what the heck... let's join and see if I can get something going here. I might even purchase it here if I can get the right deal.
I have been doing some window shopping and find a budget of £800 as far as i can go yet an unavoidable limit. Now as funny as this might sound I basically ended up on No competitors putting together an example kit which I have no intention of purchasing yet think it would be a good basis for my budget. Although i have found I have a cooling issue and a PSU issue and no doubt you guys may have advice that I should follow that could break the budget.
I do game (CoD mw3 etc) but I also do multitask a lot with 3D tools, engines and editing and find my i3 with 550ti and 4GB does fall over at times although more ram would probably solve a lot of that.
The minimum spec I want is as follows
i7 3770k or 3820k (unsure which is better)
MoBo : no idea where to start
16GB (2x8) (expandable to 32 (64?))
2 x nVidia
one pci slot for pro sound card
2TB HDD to start with
PSU (unsure of what power is needed)
Win 7 Pro
All of this on No competitors or competitor pricing with a 3770k asus board and i think a 650w psu. As I say i have no real intention of buying from ****** as i wish to purchase everything from one store which is a rule I usually try to stick to.
Firstly I don't know which processor to go with and although i hear things about overclocking, I'm not inclined that way very much at all and previous minor experiments have failed for me.. I'm no guru. # Also, I am a little stumped on cooling for it as I see some chips (all?) come with no heat sink and fan which lead me to read up and look at liquid cooling for the first time.
For the mobo, I saw the Saber (asus) and thought I would love it but its twice what i can spend. previously I have had asus, gb and such but always intel based boards but i want the memory to run fully capable where applicable.
I don't know if an 8 ram slot mobo is possible in this budget nor do I know if you can even buy a single 16GB stick making 64 in four slots possible.
Gfx must at least equate to 550ti standard but this time running 2 and I think the budget allowed for a small £150 for both. Is this feasible or would I be better getting one that can outdo two for the same money ?
If I run 2 x Gfx I need room for one pci slot for my sound card which of course changes what boards can be used.
Drive wise, 2TB sounds about right at the moment given the price. I wouldn't mind buying 2x1TB but that's more money from what I have seen.
Finally is the PSU... I just want to drop to my knees and beg for advice on this, especially if liquid cooling is going to happen and there are issues with powering everything without coming close to the limit. I don't mind using upto 75% but that is about my tolerance level for this. if I am going to use 750w of power I want a flat 1kw psu. I am aware of some of the tat out there claiming to power small villages yet fail to run a pentium one efficiently.
So you can know where I am coming from : I watched a friend build my pentium 1 on the same budget years ago and have built my own since. I have my i3 and 2 core2 duos running strong for the mrs and kids and have done the p2 pIII and p4s in between aswell as working 1000's of rebuilds over the years plus fixing for people... however since i3 era landed i haven't been doing much so my knowledge is lacking and I realize i7 and liquid cooling and the rest is something I had better find some solid research on before I jump in feet first and throw my budget at the fan and get covered in some mess.
Thanks for reading and if you can offer some ideas on great bundles and all or some of the above, i truly appreciate it. I have still to save up more money so am not ready yet which is good time to take a semi serious look in a see what i should do and avoid.
Edit : somewhere in this is a budget for a £35 case. Not interested in ally, just a nice fresh case will do me. Not long bought a CiT for my i3.
Sorry but I will only do intel and nvidia.
Any reason for i7 over i5? The smart money goes on i5 unless you're doing a lot of video encoding or 3d rendering.
With regards to graphics, stick with 1 card rather than 2 unless you're going for a serious graphics monster such as 2 x GTX670s or GTX680s. For your £150 graphics budget you're looking at a GTX650 which isn't going to set the world on fire. Personally, I'd swap the i7 to an i5 and then put the cash difference in to a GTX660ti.
This is all assuming you want to do some gaming at a decent resolution.
budget is nowhere near enough for the parts you have listed, a i5 with a single card is all you will get at max unless you lower your spec or up your budget tbh
just for show not a build list or spec either,
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £279.95
1 x Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-04649) £119.99
1 x GeIL EVO Leggera 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (GEL316GB1866C9DC) £89.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £79.99
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £76.99
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £34.99
1 x Xigmatek Asgard Midi Tower Case - Black £28.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £741.98 (includes shipping : £11.75).
all value stuff, low end stuff exc cpu, with no card picked as budget is too low to get one,alter your mind, or get real low end parts and a poor miss match of a pc...
never mind what you want, it's more like what you can afford on your budget, which won't be anywhere near your spec/wish list either to be very brutal and honest
for me i'd g for something in budget like this,
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £259.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Asus P8Z77-V LX2 Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £54.98
1 x GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (GEL38GB1866C10DC) £49.99
1 x Windows 8 Pro Upgrade Edition - from XP SP3 / Vista / Windows 7 £44.99
Total : £810.91 (includes shipping : £12.50).
and here are my reasons, first of all, budget!
second, budget,
a i5 on a 1155 socket as you can't afford the next one up, either a i7 or on same socket or a 2011 socket
8gb of ram, same answer as above
a amd card as it's in your budget and a lot faster than anything nvidia can do for the same money, enough said there tbh, value over make on a very tight budget....
a basic case, which is just a box, all thats needed, but not gone too low on a psu, which if you do cut corners could take down the whole system
a 2tb hdd, no money left for sdd, not even a small boot one.
gone for windows 8 upgrade, as you have a o/s and tbh can't afford pro, and for gaming it's slower anyway eg win 7 home is always faster than pro, as it uses more resources, unless you manually turn off all those you don't need, and if so you might as well have bought home anyway, home is for home users, pro is for networking, so unless you have a small server and network, it's not needed and your budget doesn't allow it either. saying that gone for win 8 64bit pro, just for cost to make budget / price given
your starting to get the picture im painting, sorry it's a black and white one
I did make a list of what you actually wanted to give you a rough actual price, but i mega skimpt on the case, im asuming if you've all the gear like this tho in reality you'd want a nice case (about 100/150) :O
YOUR BASKET
2 x KFA2 GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card with a free copy of 3DMark advanced edition £299.99 (£599.98)
1 x Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI316G160C9K) £79.99
1 x Corsair Builder Series CX 750w Modular '80 Plus Bronze' Power Supply (CP-9020061-UK) £78.98
1 x Cooler Master Elite 330U Midi Tower Case - Black £34.99
Total : £1,384.96 (includes shipping : £11.75).
Like the above folks said theres no need for an i7 if your just looking to game.
i use a i7 for gaming and 16gb of ram and a single card, the setup is great for modern stuff, i play total war stuff, so big maps and large to very large armies, apart from that a i5 will be plenty unless you want to double your budget, as that what i spent to get a i7 gaming rig
Thanks for the replies folks but between me not realizing discussions here are limited to this store only and me realizing I need a more open discussion, I think this has been a complete waste of time.
As for the budget, it was based on a real basket at a store I said I won't be using.
Moderator, you can go ahead and nuke this debate and my account.
Are you sure the prices were right where you were looking?
It would seem what you were looking at for the price would actually be pretty impossible.
