I have a 2700K....
18 Mar 2011
East London.
....it does 4.7 @ 1.32 stable. It does 5.0 at 1.42 stable.
I am downgrading from EATX to MATX, changing Mobos from Gigabyte UP7 to Gigabyte G1 sniper M3.
Is there any logical reason for me to upgrade my CPU to an IVY B 3770K. I understand its about 10% faster but is that 'worth it'?
Once i have downgraded in size i do not expect to upgrade for a good few years hence enquiring about the 3770k
Does my 2700k take advantage of PCIE 3.0? If not, is getting the IVY B to take advantage of PCIE 3.0 viable or not considering my situation.
PC will be used for gaming, video rendering and normal tasks, nothing too heavy in all three aspects.
Thanks
Don't think it would be much of an upgrade, the newer chips need better cooling to reach your speeds.
That was my inital thought, but then i thought i will get a few other opinions and see what the general gist is. I was aware of the cooling issue with the Ivy B's, i think most have overcome this by delidding....not something i think iwant to mess about with, purely down to time and laziness.
the 2700k doesn't enable pci 3.0, only 2.0.
If you are running just one graphics card a pci-e 2.0 x16 is more than enough.. you have a good chip, my 2600k could do 4.5 with 1.28V, with my 3770k I need the same 1.28 to get 4.5 and my 3770k runs hotter.
Yeh just the one HD 7950 for me. Will upgrade in future but just the GPU, dont think the CPU will require an upgrade for some time yet.
you wont notice,only in benchmarks, pcie3 adds less than 1% over pcie2
Is that all it is? Theres me thinking it was going to be like a very healthy %age increase.
If you want to upgrade get a 3930k and a micro ATX board as the 2011 socketis exspecting new chips if you should ever want to upgrade ;)
My current cpu does what i need it to without too much stress so wont be upgrading just yet. But socket 2011 is something to consider for sure when upgrading.
thanks
What about the 3820? Much cheaper, and despite it having only a partially unlocked multiplier still seems to be quite clockable on the right board.
5 @ 1.42v stable. No, keep this chip :)
Well its 5.0 at 1.4v
Load line notches it up to 1.41/42
I keep it @ 47 multi with 1.3v and load line takes it to 1.32
I have decided to keep it. Silly on my part ti consider an upgrade to ivy b when i have this performance.
Max temps at 5.0/ 1.42v are 75c. Watercooled.
