Seasonic PSU's *** Arriving next week ***
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Seasonic S12II 430W '80 Plus Bronze' Power Supply @ £49.99 inc VAT
The S12II Bronze Series achieves the 80 PLUS® Bronze standard of at least 82%, 85% & 82% power usage efficiency at 20%, 50% & 100% operating loads respectively. This, combined with Active Power Factor Correction, enables the S12II Bronze to reduce energy waste, boost power efficiency and more importantly, reduce the energy costs for the users.
In addition to the efficiency upgrade, the S12II Bronze Series maintains the strong foundations of the S12II series. Important features such as the stable and proven Double Forward Converter circuit design, the industry leading Smart and Silent Fan Control (S2FC) and the use of high reliability Japanese brand capacitors are all carried forward to the “Bronze”.
The S12II Bronze Series, similar to its predecessors, is available in the standard ATX Form Factor and in wattages that are most common for a PC system. In addition to the all-in-one cabling design, the 520W and 620W models come with additional EPS connectors for IPC and server systems and supports both 6P & 8P PCI-E connectors for the most current and high end dual graphic cards.
- 80PLUS® Bronze Certified High Efficiency
- Highly Reliable 105 degree Japanese Brand Capacitor
- Ample +12V Outputs
- Active Power Factor Correction [99% PF Typical]
- Double Forward Converter Design
- Smart & Silent Fan Control [S2
FC]
- 12cm Ball Bearing Cooling Fan
- Soft-Mount Rubber Cushions
- Universal Video Card Support
- All-in-One DC Cabling Design
- Patented Easy Swap Connector
- Universal AC Input [Full Range]
- Ultra Ventilation [Honeycomb Structure]
- 3 Year Warranty
Only £49.99 inc VAT.
ORDER NOW
Seasonic S12II 520W '80 Plus Bronze' Power Supply @ £59.99 inc VAT
FC]
- 3 Year Warranty
Only £59.99 inc VAT.
ORDER NOW
Seasonic S12II 620W '80 Plus Bronze' Power Supply @ £69.98 inc VAT
FC]
- 3 Year Warranty
Only £69.98 inc VAT.
ORDER NOW
The 430 Watt is a good price, its only gone up a couple of quid in price compared to what I paid for my old Seasonic S12 430 back in late 2006. Its still going strong in my sister's PC & its been in at least half a dozen of my builds before then. Very quiet too, which is a testament to its longevity and reliability. :)
Quality is similiar, but the efficiency isn't quite as good, but the pricing is reflective of this :)
