What the hell, entered those 120 codes and it's reset my account to 0/120 codes?
I clicked verify integrity of game cache because the patcher wasn't working properly...then it started downloading a massive update.I didn't have any patches this morning, you sure your game hasn't corrupted itself or something?
This is for both PC/PS3 "Xbox doesn't out cause it never works", Loading screens of doom, Weapons deleting if left in Salvage Matrix on a crash or server down, unable to use mission item so forcing you to log out, 90% of the contracts are broke, voice works 20% of the time, and Dungeons don't auto party now so yeah.... ****es me off cause these issue were in alpha and never got fixed
Yep and patching ont eh 360 aint simple like the PC, no rolling stuff out willy nilly, got get it auth by MS first and cleared etc, good luck with that
^^ No you're not.
There are no classes, if you picked survivalist you will have entered the game with a sniper rifle but you will be just as good using a assault rifle as the...assault rifle class.
Its just different outfits.
^^ No you're not.
yes i am, I choose to use a Sniper ONLY, Hence i am a Sniper.
You use a sniper in close combat?
Im using a sniper and pistol only, ego rating 462 so far, not really had much trouble apart from some of the missions with those tanker dudes and the elite launcher skitterling things, but get distance and its no issue.
