Best budget 120mm fans
4 Mar 2008
Wandsworth
Looking to get a couple of 120mm fans to have my rad in push pull.
What are the best fans for <£8 with the best CFM:Noise ratio?
Cheers
Performance
Noise
Price
Pick two not three ;)
Good compromises I find are Scythe slipstreams which are about £8 and come with a variety of noise/airflow options, something PWM might be good too as it should be less loud when the system isn't hammering games (which will be making noise) /shrug
Assuming you were after two, for push/pull on a 1x120 rad, instead of paying £8 a fan get these for almost £16:
YOUR BASKET
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack £13.99
1 x Arctic F8 Case Fan - 80mm £2.59
Total : £16.58 (includes shipping : FREE).
Then smash the center out of the F8 to make a shroud and run just the Corsair shrouded in push ^^
Yate loons are pretty highly regarded amonst watercoolers as a cheap but decent performing fan. They usually cost a fiver a pop. Ive used them as case intakes/exhausts and on a few cpu coolers. Couldnt fault them for the price.
Yates are brilliant for the price
