- 20 Jul 2009
- The bleak North East arm pit of Britain
You guys asked for it, Edifier and OcUK have just delivered it!
Edifier R1600T Plus 2.0 are BACK for a fantastic one week only price of £49.99inc! Awesome price before, awesome price now!
Enjoy!!!
Edifier R1600T Studio Plus 2.0 Monitors @ £49.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
Was £59.99 Inc. VAT originally for This Week Only!!
Now Only £49.99 inc VAT for the remaining This Week Only Period!! Ends Wednesday the 17th at 10AM!!
ORDER NOW
Enjoy!!!
- Distortion: 0.1%
- User manual
Was £77.99 Inc. VAT
ORDER NOW
