** Aqua Computer Kryographics for GTX TITAN **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Brand new from Aquacomputer, Acrylic topped 'glass edition' VGA blocks for GTX TITAN.
These acrylic tops look incredible and frankly are the nicest looking blocks available for TITAN.
Stock is due very soon.
If you want ultimate Peace of Mind
Why not consider a Tech Labs card and let us take care of the installation for you!
Aqua Computer Kryographics for GTX TITAN Acrylic Glass Edition @ £89.99 inc VAT
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX TITAN with 6144 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The cooler is manufactured out of copper with an acrylic cover, the connection terminal is made of Delrin. We recommend straight plug&cool connectors as fittings. For SLI setups the connection terminal can be replaced with the kryoconnect terminal (sold separately).
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4.
Only £89.99 inc VAT.
ORDER NOW
Aqua Computer Kryographics for GTX TITAN Acrylic Glass Nickel Edition @ £98.99 inc VAT
The cooler is manufactured out of nickel plated copper with an acrylic cover, the connection terminal is made of Delrin. We recommend straight plug&cool connectors as fittings. For SLI setups the connection terminal can be replaced with the kryoconnect terminal (sold separately).
Scope of delivery:
Please note:
Only £98.99 inc VAT.
ORDER NOW
Aqua Computer Kryoconnect for Kryographics 1 and 2 slots - SLI bridge @ £16.99 inc VAT
The kryoconnect direct connection kit allows to directly connect two graphics card waterblocks (kryographics series) and can be used for SLI or Crossfire systems.
The kit comes with a connection block made of Delrin which replaces the connection blocks of the individual water blocks. The graphics card may have a spacing of two or three slots (meaning one or two slots remain unused between the graphics cards).The unused connection can be sealed with a stainless steel plates which is included in delivery. A sealing screw is also supplied and can be used to determine whether the waterblocks are connected in parallel or in series.
Suitable for the following waterblocks:
kryographics for GTX Titan (art. 23547, 23548, 23549, 23550)
Works with one or two unused slot between the PCIe slots.
Scope of delivery:
1 connection block made of Delrin
1 sealing plates made of stainles steel
2 gaskets
3 screws
1 sealing screws
Please note:
Water blocks, graphics cards and fittings are not included in delivery, please order separately. Threads are G 1/4. SLI/Crossfire operation is also possible without this conversion kit using bent fittings.
Only £16.99 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX TITAN 6144MB GDDR5
THE FASTEST VGA CARD ON THE PLANET
The new Geforce® GTX TITAN graphics card ships with 28nm NVIDIA® GPU and 6GB GDDR5. To fully harness the power of the GPU technology,
The OcUK Tech Lab H2O GTX TITAN combines the fastest Graphics Solution on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the mind blowing GeForce GTX TITAN 6144MB, the OcUK Tech Lab H2O Custom GTX TITAN allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
This graphics card comes complete with your own choice of VGA block styles from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
Features:-
- Gigantic 6GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
* All graphics cards are blocked and fitted to order so please allow a lead time between 24 - 48 hours.
ORDER NOW
