- 7 Mar 2013
- Caistor
Want to ask for some advice for the fan configuration of my system...
Case: NZXT Phantom 410
CPU: i7-3770K @4.5G | Cooler: Corsair H100i
Graphic: Sapphire HD7970 Vapor-X
In case you are not familiar with the case:
H100i mounted on top of the case - with 2x120mm fan
front: 120mm x 2
side: 140mm / 120mm x 1
bottom: 120mm x 1
rear: 120mm x 1
I am wondering whether I should set up the push/pull as follows:
Exhaust: top x 2 + rear x 1
Intake: side x 1 + bottom x 1 + front x 2
Also, can I have some advice for choosing fan please?
I am thinking of getting a whole set of Noctua NF-P12 (or P14 for side), not sure whether it is worth it to change for H100i?
And is there a decent fan controller that I can use for these fans?
(I think most fan controller can control up to 4 fans only.. which one should I not control??)
Kind of new to desktop config
so please help..
front: 120mm x 2
bottom: 120mm x 1
rear: 120mm x 1
