No matter what I try, AMD drivers will not install. (7950's)
Are you using VIRTU? If Yes, and your VGA cable is connected to your mobo then uninstall Virtu, connect cable to GPU instead of mobo and then install Catalyst.
Even if you have Virtu installed and are not using it, uninstall it anyway and try installing catalyst again.
yuk, I feel your pain man. I had exactly the same issues going from NVidia to AMD a few years back. Spent 10's of hours trying to fix and never did. Thankfully you got it sorted after a reformat I never did, will never buy AMD again...
Indeed, totally AMD's fault.
