Can I run GTX580 on OCZ Modextream PRO 500w ??
12 Mar 2013
Hi
As in topic. Is it possible to run that graphic card on my PSU?
My spec right now:
cpu - i5-750
motherboard - ASUS P7P55D
PSU - OCZ Modextream PRO 500w
RAM - 4GB DDR3
GPU - RADEON HD5850 DCU2
CPU is overclocker to 3.8GHz - works stable.
The ModXstream Pro's are far from being the best PSU's out there, your particular model has 432W on the +12v but I think it should be alright.
The ModXstream series is a funny bunch...
The 500W has a total output of 598W with 432W on the +12v
The 600W has a total output of 670W with 504W on the +12v
The 700W has a total output of 718W with 552W on the +12v
No idea how they worked out the '500W', '600W' and '700W' names for those three :rolleyes:
That is the maximum power draw on the transformer
Or safe power draw
But if the 12V can only handle 432W that is a problem :)
2 Years age will reduce power output
The word is that 1 year has a 10% impact on performance
You can only see if it works or not but get another PSU in a couple of months
Nvidia state a minimum of a 600W supply for the 580.
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-580/specifications
I think we all know that this is a very cautious estimate and that the card can run happily on a lower wattage supply depending on what else the supply has to feed of course.
I've always been a believer in leaving headroom when buying your PSU. Trying to buy a PSU that exactly fits your power demands leaves you sailing close to the wind and without any upgrade options. Cost isn't really a sticking point with PSU's, just pay a little extra and get a slightly beefier one.
The newer OCZ PSU's seem to be pretty darn good. The ModXstreams have a bad reputation and a bad write up however.
I don't want to hate on them, I own one (bit of a mistake on my part when I built my PC) but they do.
