*breaking news* Boston Marathon explosions
In actual fact the other larger electrical circuit board looks similar to a 2.4ghz RC receiver minus the cover, looks like its got a servo style connector on the far right of the pic.
The colours look more like it's from a servo - if you look, most (if not all) receivers have female plugs for cables to plug into from the speed controller and servo. That said it's a bit square to be a servo.
True, looks like it, depends how it's wired though. Slightly confused by the 10awg servo wires though, ends of the battery wire look clean stripped and not burnt, servo wires are burnt, driving a servo with 7.2v is going to be interesting, that's unless they only used 4 cells.
Unless the burnt end is the one which set the detonation cap off.
So with the above in mind looks like the bomber wasn't a million miles away from the blast, and would have been watching.
Not wanting to discount anything... but it's possible some of those wires are from people's camera's/equipment/stuff in their bags/other sources that were caught up in the blast.
Battery pack, deffo not, smaller circuit board, perhaps, larger one, doubtful.
The larger board is the perfect size and shape for a RC model car receiver, if you searched hard enough on google you could probably find the make.
Stuff like the above can be purchased without any issues, are super small and doesn't need the GSM network to be alive to set the bomb off.
Someones modified the board though, the power wires going to are far larger than the standard 4.8 or 6v packs need.
In addition i think the smaller electrical board is actually whats found at the bottom of a full sized RC servo, the silver thing hanging off at the bottom of the board, originally i though was a cap, but it could actually be the servo motor itself.
If you look at the corner of the servo board you have curves, this is the location in which the screws pass to keep the servo case and gears together, all the servos i've taken apart seem to have ghetto soldering and that board has the same.
If you look at full sized servo dimensions you get this:
http://www.mindsensors.com/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=98
M = 39.88mm
The ruler scale in the image puts the board at 40mm.
Following on from the other one yesterday... (or was it Monday?)
The Associated Press ‏@AP
Officials: 2nd letter addressed to Senate intercepted, being tested for poisonous ricin.
And one for Barack as well.
BREAKING: Secret Service: Letter addressed to Obama contained 'suspicious substance'.
Peter Alexander ‏@PeterAlexander 6m
Secret Service confirms to @NBCNews letter sent to Obama Tuesday contained suspicious substance & was intercepted.
Michael Skolnik ‏@MichaelSkolnik 4m
BREAKING: a letter addressed to Obama contained "suspicious substance," being tested for ricin. Sent from same person who sent ricin to Sen.
edit------------>
Apparently a lid from one of the pressure cookers (or the) was found on a rooftop.
The larger board is the perfect size and shape for a RC model car receiver, if you searched hard enough on google you could probably find the make..
I think you could be right, the cable on the right of this image has what looks like a 3 pin servo cable connector on it. this is what they look like http://imgur.com/IHdBSXJ
It's exactly the cable that would be coming off a RC Rx. Well technically it could be any sort of electronic header cable but it does fit quite well from what we can see.
If the person who set it off was using 2.4ghz RC Tx/Rx he couldn't have been much more than 1000ft away (about the maximum line of sight distance on the ground for that type of radio).
Yep, i'm quite sure those who planted and exploded this bomb watched it go off, they will be on camera / cctv, it's 'just' a case of finding them in the mass of images and video.
It's confirmed as Ricin, in both letters. Can't see if this has been posted yet?
http://www.bbc.co.uk/news/world-us-canada-22190031
The letter addressed to the president has tested positive for ricin, according to US media reports, but the contents are being sent to an accredited laboratory for further analysis, as the preliminary results need further verification.
It arrived at the facility on 16 April, the same day a letter intended for a US senator tested positive for the lethal toxin ricin.
its probably old news in this thread, but 4chan may have found them already:
http://weather-underground.tumblr.c...pens-when-you-give-4chan-images-of-the-boston
i'm not saying that this is the person, but it is suspicious that a very similar backpack has been found within the explosion to the one he was seen to be wearing, then later seen without. he could be totally innocent but the lead is definitly worth persuing
Nope, that is the electrolytic cap, note the plastic coating ripped off it, the top seam and the yellow tantalum cap next to it
Agree, the PCB has cutout corners only on one side suggesting this has been blown in half (all corners should look the same)
Not convinced it is a servo though, what would it do?
The moulding in the casing is the same size at the wires, suggest wires are OEM for a high cap pack.
They've been stripped down and partially used as a trigger mechanism before - probably easier than removing them entirely if they are reusing the remote control side of RC planes as the trigger.
OK, thinking about it, it makes a cheap switch (like the solenoid starter on a car).
(continues to be disappointed at the lack of sophistication)
This Internet speculation and analysis of the video and photos is incredibly dangerous. This could potentially ruin innocent people's lives.
If something is going to blow up you dont want to spend too much now do you. Proven reliable parts no matter how crude kinda makes sense.
Suggestions that the brown smoke seen after the explosion points at Tannerite, freely available in the US.
http://en.wikipedia.org/wiki/Tannerite
(forward to 0.44)
