http://www.youtube.com/watch?v=eR-A9YfVOZk
Does that sound like a clutch bearing?
Is the creaking noise you putting you foot on the clutch?
Does the noise start when you depress the pedal and does it stop when you take your foot off the pedal?
Yeah that'll be the release bearing.
Gearbox will have to come out and new release bearing fitted. Might as well fit a new complete clutch kit while its out.
What car is it? Make model year etc.
What size engine?
