Pondering an amp upgrade
Man of Honour
20 Sep 2006
My Sony 820 is getting on a bit now and I've thought about replacing it. I've had a look around and for what I'm willing to spend (£500 or so) I'm swaying towards the Yamaha RXV773. Any others at the price range worth looking at?
I'm also after some speaker cable if anyone has any recommendations?
Hi I don't usually post in hi-fi sections but I read this and may I pitch in.
Your Sony amp is a cracker, they are not worth much secondhand why change?
Sound engineers often use regular 13amp power cable for speakers, electrons are not fussy.
If you take my advice your going to be loaded!
Well for some reason it is switching modes by itself and it also has a habit of locking down the screen and not displaying anything at all. Only cure seems to be a full reset.
Buy second hand, you will get much more for your money.
I have a Pioneer LX53 for sale over at AVF for well in your budget, was £1100 new, 7.1 with latest codecs fully supported.
I installed a couple of 771's early last year and was really impressed by the range of features and sound quality. Previously I have sold and installed mostly Onkyo, Denon and Marantz.The 773 is more of the same and it's cheaper than the 771 too.
The only thing on my wish list would be a little more oomph from the rated power. Don't get me wrong, it's sufficient 95% of the time but I have been spoiled with larger amps and pre-power combos which go loud and still have plenty in reserve. Having said that I bought a Yamaha for home use after installing those others and the wife keeps telling me to turn it down, so it can't be too short on juice :D
One thing I like about the 773 is that it has pre outs so I could wire it up to a hi-fi amp for those occasions. Hmm, to ponder.
That's how one of those 771's was hooked up. It's a combo that works particularly well for Hi-Fi and AV. In this case the Hi-Fi amp is a Lavardin and the front stereo speakers are Focal Chorus 826. The sound is pure and unsullied for music, and absolutely epic for movies. The rest of the speakers are Monitor Audio.
My own system at the moment is based on a Yam 765 with pre-outs driving a Creek 2 channel stereo amp to my JM Labs speakers.
Going the pre-out route opens up a lot of possibilities. It is well worth the little effort required to try it.
This makes me ponder pre out setup myself.. Sorry to jump in but is it really that much of an improvement?
Have a 1067 with rx6 fronts
The answer for you depends on the stereo amp and whether you can hear much of a difference between music via that compared to music via the Yam. If you have a friendly dealer see if you can borrow a decent Hi-Fi amp for a home dem and then do the comparison.
I saw a marked improvement in stereo sound when I added a stereo amp to my set up, my yammy on it's own sounded very good (RXV-3900), but the addition of a stereo amp with HT bypass (Musical Fidelity M3i) took it to a whole new level. When I looked into it, I was advised that an AV amp has stereo capabilities of a stereo amp a quarter of its price, so if your looking at a £500 AV amp, your essentially getting stereo quality of a stereo amp worth £125. Obviously that's not a cut and dry example as some will be better than others, but its something to consider.
Sorry to hear that. I had a google, can see people having issues but not exactly like yours.
Have you tried emailing their support in the UK? Nothing to lose?
http://www.sony.co.uk/support/en
I used to toe the line on that, think it's BS now for the most part. Unless there's some processing changing something or it's actually too weak an amp it'll do.
At the risk of starting another "it's reals vs it's placebo" flame war, I'll say I can appreciate where you are coming from but respectfully disagree.
In my own experience as a music enthusiast, and also as a retailer/installer of Hi-Fi and AV gear I have come across products that diminish and mask the differences, and also people whose idea of what Hi-Fi should sound like means they're looking for something different: Other's might describe it as detailed or precise but I tend to think of it as a stark and somewhat passion-less representation.
I have also had experiences where old bits of Hi-Fi have been outclassed (IMO) by new AV gear. Though that's more a case of the old being either a poor example of the breed or rather tired.
I know the above will drive the subjectivists nuts... and before too long we will hear the inevitable cries for double blind tests and that all cables/amps/sources etc sound the same. It still doesn't change the fact that I enjoy music far more through a modest Hi-Fi than I do through a significantly more expensive AV pre-power or the AV receiver I have in my system at the moment. So in my view it's well worth pursuing the Hi-Fi amp route where the AV amp allows it.
so are you saying it is better to have a hi-fi amp and use the "arc" function of your tv to feed audio out, so all hdmi's go straight into tv then out through the hdmi arc into amp where sound is then output to speakers?
rather than have an a/v receiver where all inputs go into said receiver and then only 1 hdmi goes into the tv.
if someone was going for a bang for buck setup what would you advise them? because having 2 amps imo seems a terrible waste of money.
err... no. Where in this thread is that suggested? :confused:
If that's your idea of what we are talking about then it's no wonder you're confused and don't find there's an appreciable difference. Blimey :eek:
Given how confused you are about the use of pre-outs with a Hi-Fi amp then I'm a little nervous of how you are defining "bang for buck". :D
Just for clarity's sake, what we were discussing was a set-up that uses a 2ch Hi-Fi amp directly driving the front stereo L&R speakers purely for analogue music sources e.g. CD player, turntable, and say PC audio in lossless via a DAC. It would also accept the front L&R feed from the pre-outs of a suitable AV amp. That AV amp would be responsible for driving only the centre, rear surrounds and sub. The AV amp wiuld handle all the digital and analogue sources that require DPL/DD/DTS and HD audio decoding. In this way the Hi-Fi chain is unaffected by all the digital processing noise of the AV amp, and that 2ch amp providing the front channel power allows the AV amp a little more dynamic headroom so you get similar benefits on the AV side of adding a power amp.
This is how they would wire together:
Does that help at all?
I suppose if we define "bang for buck" as getting the best Hi-Fi performance for ones money, then in that sense I would say that the two amps solution would be better than solely using some über AV amp for everything. Much though depends on what the listener is looking for and their priorities in the longer term.
As I see it, the Hi-Fi industry is pretty mature. So 2ch Hi-Fi amps aren't evolving as radically as their multi-channel AV cousins. Virtually any decent 2ch Hi-Fi amp from the last quarter century will stand up pretty well today. AV amps are a different kettle of fish. There's constant pressure to upgrade to keep pace with new technology and features. Manufacturers also face cost-cutting pressures to include an ever-larger arsenal of features at the same (or lower) price point. Somewhere in that mix the maths on AV amps doesn't add up.
Raw materials costs continue to rise. The benefit of cost reductions from Chinese manufacturing are being eroded because a) everyone else is there now, and b) wage bills in China are rising. Then there's the costs of integrating all the latest technologies and their associated licensing (HDMI, HD audio processing, 3D, video scaling, streaming features, Bluetooth/Wi-Fi/networking, AirPlay, Apps, THX, more wattage, more channels, etc etc). All of these things pull money away from what is the heart of any amplifier... a whacking great toroidal transformer and some huge high quality capacitors. It stands to reason that if you have less money to spend on those items then the quality of the final product will take a hit.
Now rewind 8-10 years. HDMI was a dot on the horizon. The AV amp market was in maturity at that point. The biggest news was DPL II and es/ex. Manufacturers were focussing on audio quality. AV amps didn't include much in the way of video scaling. Proportionately more money was spent on decent amplification. This is why an older AV amp doing DD/DTS processing can often beat its modern counterpart doing True-HD/Master Audio. The advantage of the better quality audio stream is eroded by the drop in quality of the amplification. Of course as consumers we aren't so aware of that change in the demo room because there's no old AV amp to act as a reference point. The mags are hardly likely to point it out either. Their advertisers wouldn't be so happy if they did. So it falls to AV enthusiasts to make those comparisons. This is why it's so difficult for owners of pre- and early-HDMI amps to find something new that isn't a backwards step sonically.
So, to bring this back to the point of the discussion, that's why there's an appreciable benefit running a Hi-Fi amp with an AV amp and splitting the duties. It also means that far less money needs to be tied up in the AV amp. I feel far more comfortable with the prospect of changing a £500-£600 AV amp to keep up with the latest AV processing developments knowing that it isn't going to wreck the music-side of my home system than I would swapping out a £1500+ AV receiver bought for it's musical performance.
makes a lot more sense now, but it seems like a lot of money when I am the only person in the house who appreciates quality, everybody else cannot tell the difference between upscaled SD and HD on a 51" screen never mind sound quality.
possibly when i have a lot of spare cash i could go down a proper setup, currently saving up for a semi-commercial treadmill for the home gym. so will need to put funds toward that first.
anyway i think it's best that i wait anyway as a/v receivers are still miles behind hi-fi amps, will wait until the gap is closer.
With both amps on will there be a miss match of sound across the front (ie it is advisable for a novice at least to keep the front 3 speakers the same) when listening in 5.1?
relating to me,, what would be a good price point to look at with my gear?
Yammy 1067
MA RX speakers
my partner definitly was like this before.. but not long ago i had to use the tv with only the built in speakers.. it was noticed.
now she even changes the AV amp settings from music to movie :p
