Turn the DSC off, problem solved?![]()
Wrap it round a tree and buy a decent M3
Joking of course. My guess is £7250.00.
The 18" wheels look too small but better than the 19's in style and have aged much better I think. Do you know what caused the problem that necessitated the engine replacement?
19s over the 18s any day of the week unless I was tracking it.
Get some CSLs.
Can anyone comment on the nankang NS2s? are they dire?
Pretty sure, I get an error code 5e5c or similar (from memory) which translates to a wheel speed feasibility above 20kmph fault which translates to the system thinking a tyre pressure is low and thus registering a wheel spinning slower or faster than the rest triggering DSC.
Thats what I think is happening anyway, I will clean it, and if that doesnt fix the issue, swap it out and go from there.
Im in a bit of a pickle as the 19s I have came with nankang ns2s on the rear with plenty of tread but I need new fronts, I think I will keep the nankangs on the rear for the summer and replace them with the same tyres as I put on the fronts. Can anyone comment on the nankang NS2s? are they dire?
