I was told that its almost impossible to use a modular psu with this case as it doesn't have room for the connectors. Unless you know of one which will?
Cheers fellas
If the PSU is 140mm long you have enough room to hide the unused cables from a non modular PSU. All my cables are hidden fine with enough room for braided extensions too.
Ahhh Acme beat me to itThe Silverstone modular ones arrr 140mm deep so those would fit quite nciely inside a Prodigy.
If your running SSD's you can put them in the side panel pocket thus removing the need for the drive bays.
500 should be find for a single card, but since you are WC'ing, you may need a bit more power.
