AMD Catalyst 13.x (12.101.2.1 April 16) "Mod"
25 Nov 2011
The KOP
Modded Driver
Originally this driver was only for ONE card (HD7790) now it is modified to support more cards.
***For Windows 8 users to install and use this you need to disable the driver signature enforcement.***
Build Info:
12.101.2.1-130416a-156000E-ATI
DriverVer=04/16/2013, 12.101.2.1000
CCC: 2013.0416.1149.19347
D3D: 9.14.10.0968
OGL: 6.14.10.12131
OCL: 10.0.1124.2
http://forums.guru3d.com/showthread.php?t=377386
Not something I going to install like but posting this just incase some of you guy want to install it.
Thanks to asder00 over on the Guru3d forum.
Not worth installing for normal users. All it does is add support for the 7790's new ASIC.
Thanks for the heads up :D I not going to install it like. But I post here because we have a lot guys always pushing benchmarks etc and thought they might like it.
Cheers guys think ill pass on this one and wait for 13.3 beta 5. If the reports im seeing are true that should be here within a week.
Where did you hear that Matthew?
13.3 beta's have been awful for me. I ain't raised a bug report because my issue is just weird... one of my cards lost 100 MHz from the OC :D.
No longer stable irrespective of the voltage. Can't even get it through 3DM11 and I pushed some very sketchy clocks through 3DM11 before.
I've found the opposite, though afterburner might have something to do with that. I've been getting more from my overclocks. 10-20mhz on the core. I heard it from a beta tester that the 13.3 beta 5 drivers will launch when the 7990 launches, 22nd-24th april.
THIS
Same for me. Initially had 1250 /1600 on an LTMatt OC Ref from MSI, but since 13.3 beta i can only complete a benchmark on Heaven on 1200 max. Anything more it just crashes. It doesn't matter what volts i apply.
Check you're GPU is geting the right volts, i found GPUz reporting my GPU getting less volts after installing 13.3, it could be why youve lost some speed.
Oh. Didn't make the connection that Thracks is the same person from overclock.net :D
Welcome!
Nice one - thracks is now posting here. Will 13.5 beta include the long awaited new memory management system?
That guy (Zealot) from overclock.net who has access to pre-betas (and presumably inside contacts) seems to think the memory manager is already implemented as of 13.3.
He also said he's been told the 13.5 betas will have general improvements in single card DX10/11 frame latencies as well as an improvement in crossfire microstutter, the latter of which was meant to be released by July (perhaps AMD meant the WHQL would come then?).
In other words 13.5 beta should be the beginning of the end of the whole microstutter/frame latency saga :).
Yeah they beta the **** outta nvidia cards ;)
Pork Pie - I thought the memory managements were a way off, and the only thing to be changed so far were fixes for specific game latency issues
A gain of 2fps onto the average and 1 fps onto the minimum of Tomb Raider at 1440p Ultimate preset with FXAA.
13.3
This driver
