- 24 Jan 2011
- Mansfield
Will you be stocking the LT, or just the top blocks?
I will look into it next time I'm in the office for you man
Ok so, is it possible to buy a Watercool CPU block for socket 1366 and later buy a bracket for socket 1150? Is there NO difference inside the block? Please answer me![]()
The blocks are all identical, it's only the mounts that are different. If you do a search for Pulse Modding Heatkiller Universal CPU Waterblock Mounting Plates you can get them for £4.49 + del and your block will then fit all current sockets.
Any idea guys when the Watercool Heatkiller GPU-X³ 79X0 Ni-Bl is coming into stock, I soooo want that block for my 7970!!!
