Custom Cable for Seasonic PSU
7 Mar 2013
Caistor
I has a Seasonic X-1250, but the modular cable which comes with it are all black in color... which is quite dull...
I know Corsair have some colored cable sets for AX1200i but I would not imagine they will work for Seasonic X1250 would they?
Do anyone know where can I get some custom cables for the X-1250?
nothing wrong with paracord as far as im concerned.
It's very cheap, easy to work with and has a nice tight weave.
It's easy to get, you dont have to wait till mdpc decides he wants your custom before buying, and there are countless colour options and even patterned ones
cant see the downside to it tbh
I had no trouble with paracord either. Just make sure you buy the american made nylon stuff not chinese PET. The only drawback to it is that it can "pick" and fray on sharp/rough edges.
This is heatshrinkless paracord that i just finished 2 days ago.
can you do this on a non-modular power supply, i just did a dusting of my pc to make it look nicer and did "try" to hide some of the cable but.....braiding would look kinda...awesome
