Iv been going by my ybr 125 owners manual for tire pressures which states the following;
Front: 25 psi
Rear: 29 psi or 41 psi if load is greater then 90kg.
Recently i got myself a haynes manual with the intention of doing small jobs myself. I noticed that it states only rider and rider with pillion. So according to the haynes manual if its a single rider the rear should be 29 psi, no mention of wieghts and what not. It only says to use 41 psi if i have a pillion.
I am shall we say a tad bit over 90kg in weight, not massively (100 ish) but enough that i keep 2nd guessing myself when it comes to the pressure.
In my shoes what would you guys be using 25/29 or 25/41?
Front: 25 psi
